Bottlehead Kits
Crack
High OB voltage and 1 LED doesn't light up [resolved]
Jimb0
2118
Jimb0
Sr. Member
September 24, 2019, 06:39:48 PM
Getting 170v at OB and the LED at A8 to Center Pin doesn't light up
Last Edit: September 26, 2019, 12:38:42 PM by Paul Birkeland
Paul Birkeland
Global Moderator
Hero Member
Re: High OB voltage and 1 LED doesn't light up
Reply #1 on:
September 24, 2019, 07:08:13 PM
Resolder the center leg of the MJE5731A on that side. If that doesn't work, posting some photos of the area could be helpful.
Jimb0
Sr. Member
Reply #2 on:
September 25, 2019, 08:46:21 AM
Still getting the same readings
Here are some pics
Paul Birkeland
Global Moderator
Hero Member
Reply #3 on:
September 25, 2019, 08:55:25 AM
Did the amp pass its voltage checks with the plate load resistors?
If this was built with the Speedball from the beginning, this could be an issue of the solder joints at A4/A5 not being solid.
Jimb0
Sr. Member
Reply #4 on:
September 25, 2019, 09:36:48 AM
I built the amp with the Speedball from the beginning.
I resoldered A4/A5 but to no avail, same readings
Paul Birkeland
Global Moderator
Hero Member
Reply #5 on:
September 25, 2019, 10:04:29 AM
Is the voltage at A8 0V or 12V?
Jimb0
Sr. Member
Reply #6 on:
September 25, 2019, 11:20:53 AM
A8 is at 14v
Paul Birkeland
Global Moderator
Hero Member
Reply #7 on:
September 25, 2019, 02:43:55 PM
The LED needs to be replaced. Sometimes they can fail from heat or pulling on the leads tightly, or if they sit in a humid environment they can end up like this once you solder them.
Jimb0
Sr. Member
Reply #8 on:
September 26, 2019, 11:03:29 AM
Thanks PB! Everything is in order now.
Bottlehead Kits
Crack
