Well this is frustrating ...
Guest · 10822
on: October 17, 2019, 12:17:25 PM
I don't think the hum was originating in the BeePre (which I have since dismantled and bought a whole bunch of parts for rebuilding).
I've been jonesing for music, so today I hooked up the Nickel Wonder preamp which has litlerally been gathering dust in a corner since I put it together. Fed it to the Kaiju. Headphones on: instant hum. So I think "!@&$ ^$%!@ **&%^# It's the Kaiju! I must of $#%&ed something up when I installed the snubbers!" So onto the worktable it goes but I don't see any problems. So I put the SII-45 after the Nickel Wonder - same hum!
So then I'm thinking I've blown the drivers in my LCD4s and that kinda freaks me out. So I rig up a headphone amp fed by the Nickel Wonder and try different HP's - same hum.
Then I changed all the cables and power cords. Same hum. Took everything off the dedicated 20A line from the box and put everyting on a regualr 15A line. No change.
Tried unplugging just about everything in the house. No change.
So I thought maybe there's something wrong with the grounding in my house wiring. But my Emotiva dc-offset filter indicates that ground is a-ok. Is there a better way to test the house ground?
So its some other noise on the mains? But what are the odds of the mains going wonky at the exact time that I install snubbers in my BeePre and Kaiju?  The City was rewiring the mains over the summer (resulting in even lower mains voltage!), so maybe that's it.  But I'm pretty sure I had both amps working silently after they did much or all of that work. So I'm doubtful. But maybe.
But it just occurred to me as I type that I did change something in the amps: I removed PB's chassis ground elevator diode mod b/c I was worried it might be interfering with all my shielding wired to chassis ground. I'm going to reinstall them and see.
What's weird to me is that I only hear the hum when the power amp (Kaiju or SII-45) is connected to a preamp (BeePre or Nickel Wonder). Remove the IC's and the hum disappears. Does that point to anything in particular as being the culprit.
Man ... I can't believe I tore down what I'm thinking was likely a perfectly working BeePre  :(
Any and all suggestions for how I should troubleshoot this will be appreciated!
cheers, Derek
Reply #1 on: October 17, 2019, 12:38:25 PM
If you have an oscilloscope that is the best way to sniff out hum issues. You can see the shape and frequency of the waveform and that helps a lot to determine the source.
Reply #2 on: October 17, 2019, 12:41:05 PM
Thanks Doc. I do have a scope. I will take a look at the mains.
cheers and thanks, Derek
Reply #3 on: October 17, 2019, 02:38:03 PM
Well, the reverse paralleled diode mod didn't help.  And just to be sure, I listened again with a solid state headphone amp and different headphones -- and yup, the same hum.
So on to scoping mains power.  This is so weird.
Reply #4 on: October 17, 2019, 03:45:42 PM
Well, I tried one more thing in an effort to narrow down the source to either inside the house or outside. I cut the breakers to everything except the dedicated 20A line that's used only for audio - no change. Still hums. So I suspect it really is something on the mains.
Offline grufti
Reply #5 on: October 17, 2019, 06:35:42 PM
You might want to try the inverse. Cut the breaker to your 20A circuit for the audio equipment and then connect a very basic audio setup to one of the other [regular] circuits in your house. Hum of no hum?
Reply #6 on: October 17, 2019, 06:58:47 PM
Good idea. But no luck. Still get hum.
I'm now wondering whether someone might have inadvertently disconnected the house earth ground.  I live in an old duplex circa 1895. The guy in the lower unit was doing a bit of reno in the basement over the last couple of months. I wonder whether he saw an old wire connected to a pipe and cut or removed it. He's away until sometime next week - but I'll ask him when he gets back. Maybe I'll need to get an electrician to put in a new earth ground.
Reply #7 on: October 17, 2019, 07:14:10 PM
Earth ground is not important for noise (only for safety ...)
What is connected to the input of the preamps?
BTW, Doc B's suggestion of using a scope to look at the device outputs and even the power line is still worthwhile. Post screenshots to crowdsource the analysis ...
Reply #8 on: October 17, 2019, 08:22:06 PM
On your nickel wonder, the output is one winding of the transformer, is that floating in your build or did you ground one end?
The symptoms you are reporting are consistent with a grounding issue, and when you make your system more and more complicated, you provide more points where these issues can originate.  Your instinct to get things down as simple as possible is a good one.  I would follow Doc B's directions to see if that leads you anywhere.
If you have just one interconnect plugged in, do you still get hum?  If you just touch the shell of one RCA cable to the shell of the jack (leaving the center pin doing nothing), does that activate the hum?
Reply #9 on: October 18, 2019, 04:32:49 AM
Many thanks PJ and PB. I'm confident that I will *eventually* get to the bottom of this.
This is good information to know. I didn't see your message until late at night, after tracking down where the main panel in the basement makes an earth ground connection: on the city water service pipe that runs about 10 feet below grade under my front yard.It was loose and corroded. So I spent a couple hours cleaning all the parts, filing to get shiny metal, and re-attaching. So hopefully my house is now safer!
Quote
My DAC. But the hum happens even when there is nothing connected to the inputs of the preamp.
Quote
Yes, this will be this morning's project. I will post screenshots of everything later today. Everyone's expertise (or even wild guesses) as to the meaning of the results will be much appreciated.
I will check that later today and report back.
Quote
Yes, I still get hum.
Quote
No. it only happens when the center pin is connected.
Different idea: I remembered this morning that in August I had a water leak upstairs. I didn't notice any effect on audio at the time. But seeing the corroded earth ground connection last night got me thinking this morning: corrosion takes time. Maybe one or both of the outlets near my audio or elsewhere on my main floor are corroded. I will safely investigate this after scoping.
cheers and many thanks, Derek
Offline Jamier
Reply #10 on: October 18, 2019, 04:47:51 AM
Derek, do you have one of those test plugs with the three lights that analyzes the configuration of an AC receptacle? It will tell you if you have an open ground. It won’t tell you about the quality of the connection, but it will indicate if your grounded or not. I always thought earthing of circuit grounds made a difference with respect to noise too, especially signal input grounds.
Jamie
« Last Edit: October 18, 2019, 04:53:03 AM by Jamier »
James Robbins
Reply #11 on: October 18, 2019, 08:44:15 AM
Scope shots attached.
Mains looks fine. Interestingly, the scope says I'm getting 121V RMS, whereas my Fluke 117 says 117 (perhaps it's biased in favor of itself). So maybe I need a new battery (again!). And maybe this explains why my voltages on checkout are always slightly on the low side.
Hum is a jagged 60Hz wave. With preamp connected but not powered on: no hum and no hum waveform. With preamp on: jagged 60Hz waveform that varies in amplitude by the SII's attenuator setting.
Please let me know if the waveform isn't clear enough, or if you want something else.
All input/thoughts welcome and appreciated.
I still suspect that my upstairs water leak in Aug has something to do with this - the water went right through the floor into the ceiling (and presumably the walls, perhaps using mains wiring as its conduit).
I am going test whether the hum is still there if I plug the amps into the wiring from the main panel rather than the sub-panel.
@Jamie - I had one of those at one time, but it's either lost or buried in some box/bin somewhere (which is as good as lost - I'll find 5 years from now when looking for something else)
MTIA, Derek
« Last Edit: October 18, 2019, 08:50:25 AM by Deke609 »
Reply #12 on: October 18, 2019, 08:49:28 AM
Forgot to answer this: It looks like I grounded it.
cheers, Derek
Offline Jamier
Reply #13 on: October 18, 2019, 08:53:00 AM
Derek,
     Is your house wired through galvanized conduit, completely? You mentioned having a dedicated 20 amp audio circuit. Is that something you added or was it present when you moved in? In those circuits that are wired through the conduit are there no ground wires ( is conduit the ground pathway)?
Jamie
James Robbins
Reply #14 on: October 18, 2019, 09:02:31 AM
Hi Jamie - no metal conduit that i know of. I should have chosen a different word. I just meant that I suspect the wiring in the walls would make an easy means/route ("conduit") for water to follow gravity.
I had electricians add the 20A line a couple of years ago and watched them put it in. They snaked a new wire directly from the box to the wall outlet.
cheers, Derek
