E80F OK substitute for EF86?
kip.duff · 3777
Offline kip.duff
on: December 25, 2019, 04:24:14 PM
I bought some nice German E80F Valvo NOS tubes for Eros 2 first stage.  Based on some info in these treads, I believed they were compatible with E86F.  But I did my voltage tests- got 1.7V at OkC and OkD with kit supplied tubes- within your recommended spec of 2.0V.  With the Valvo tubes, I got 2.3V amd 2.5V.  Is this a risk running these?  Not an acceptable substitute?
Thanks, Kip.....
Dr. Feickert Blackbird II w Reed 2A tonearm and Lyra Skala cartridge.  Eros 2.  Audio Note DAC 2.1 Signature.  BeePre with BeeQuiet and Paramount 1.1 monoblocs into A7 VOTTs or Nagoaka folded horns.
Reply #1 on: December 25, 2019, 06:48:48 PM
I personally wouldn't use them.  They use a bit more heater current, which isn't ideal for the 6.3V regulator.  They will also have less gain and likely a little more noise than an EF86.  The linearity of the EF86 with ~100V on the screen looks quite a bit better with 1.5V of bias than the EF80 with ~100V on the screen and 2.5V of bias.
Still, the Eros 2 will function as a phono preamp using them.
Offline kip.duff
Reply #2 on: December 25, 2019, 07:38:35 PM
Ya- didn't seem right.  Glad I asked
Thanks for response- Kip.....
Offline kip.duff
Reply #3 on: December 26, 2019, 04:03:13 PM
I don't know why I wound up with these Valvo E80Fs.  EF86s are affordable.  All kinds of EFT, Telefunken, Valvo NOS or "test-NOS" offers on eBay.  NOS matched pair of Bugle Boys or Mullard (Holland) under $100 pair on the high end.
