Very faint hum
Jimb0 · 14978
Reply #15 on: January 23, 2020, 10:08:10 AM
Hmm, maybe post some photos of the build.  Perhaps there's something we can spot.
Offline Jimb0
Reply #16 on: January 23, 2020, 02:03:45 PM
pics
Offline Jimb0
Reply #17 on: January 23, 2020, 02:10:16 PM
The rest of the pics
https://imgur.com/a/59SiQVd
Reply #18 on: January 23, 2020, 02:10:54 PM
The black/red twisted pair of wires needs to be way, way far away from the input wiring.  In the stock build, it wraps around the back of the OT-3 (it won't do much harm there), but in your build it has been brought back and run in parallel with the input wiring.
Offline Jimb0
Reply #19 on: January 23, 2020, 03:14:20 PM
going to test it now
Offline Jimb0
Reply #20 on: January 23, 2020, 03:19:04 PM
Hum is still there :/
Offline Jimb0
Reply #21 on: January 23, 2020, 03:22:36 PM
Btw I resoldered all the wires except for the C4S boards and the wires under the C4S boards
Reply #22 on: January 23, 2020, 03:27:59 PM
Can you double check the output of the 6.3V DC supply on the power supply board?
If that looks good, clip lead the center lug of each 6C45P socket to the ground buss wire and recheck to see if the noise is still there.
Offline Jimb0
Reply #23 on: January 23, 2020, 04:08:03 PM
Clipped both 6C45P center lugs going the ground buss but I can still hear the hum faintly.
Offline Jimb0
Reply #24 on: January 23, 2020, 04:12:03 PM
The hum is almost inaudible but I can still hear it faintly
Reply #25 on: January 23, 2020, 06:47:49 PM
Remove those clip leads and clip them between terminals 5 and 10 on each output transformer (where the teflon wires connect).
If the original test reduced the level of hum, that is indicative of noise being picked up in the wiring going from the RCA jacks to the selector, attenuators, and tube sockets.  If the noise is not dependent on the position of the attenuator (which you indicated before), then I would be suspicious of layout issues.
The Mainline is exceptionally sensitive to layout, and any deviations present the possibility of problems, so this may be a rather difficult issue to track down.
Offline Jimb0
Reply #26 on: January 24, 2020, 04:17:32 AM
Just to be sure I clipped the correct wire from the 6C45P socket. It's the red and white wire going to the bottom tabs of the attenuator correct?
Offline Jimb0
Reply #27 on: January 24, 2020, 04:23:21 AM
Also what do you mean by clip leads of the wire between 5 and 10?
Should I be rerouting the bottom tab of each attenuator to terminal 5 and 10?
Reply #28 on: January 24, 2020, 04:46:24 AM
Clip leads are wires with alligator clips on the ends.  I'm not suggesting that you cut the wires...
Offline Jimb0
Reply #29 on: January 24, 2020, 05:58:20 AM
Did I do this right?
https://imgur.com/a/5T0WtJi
