Power supply - choke resistance
Kermit · 3157
Offline Pingu
Reply #15 on: January 05, 2020, 04:22:41 AM
Kermit and Fromnowon
yes that’s the picture and I found the write up clear and helpfull with sensible advice about upgrade bits glad you liked it too.
Paul
thanks for the advice yes I intended to earth the choke separately but will now make sure it’s insulated from the base plate too, thanks
My first job is to sort out several dry joints. No not my build I inherited the crack from a friend so just giving it a check over before running it and then after that trying the caps and choke upgrades
Martin
