Power supply - choke resistance
Kermit · 3170
Offline Kermit
on: January 01, 2020, 06:25:42 AM
I bought a Triad C-7X to replace one of the power supply resistors.   It's resistance measures a bit on the low side - 240 ohm.  It's within spec for the part, but seems low compared to the stock resistor.
Is this safe to use, or should I buy another one and hope for a part with higher resistance?
Offline Tom-s
Reply #1 on: January 01, 2020, 06:43:47 AM
It's ok. Go ahead. Use it in place of the second PS resistor.
Reply #2 on: January 01, 2020, 06:48:54 AM
Ditto. By my rough PSUD estimate the 240 DCR of the choke in place of a 270R resistor will only increase B+ by 2-3 volts - which is pretty small. The mains voltage coming out of the electrical outlets in your home probably bounces around by this much or more.  So you should be fine.
cheers and happy new year, Derek
Offline Kermit
Reply #3 on: January 01, 2020, 07:13:59 AM
Just checked my voltages - they're a tad high (before installing the choke).   B+ is 181, and the big Speedball has OA and OB at ~108.5.  Still ok?
« Last Edit: January 01, 2020, 07:19:02 AM by Kermit »
Reply #4 on: January 01, 2020, 07:32:10 AM
That is within the acceptable range.
Offline Kermit
Reply #5 on: January 01, 2020, 07:51:28 AM
Great, thanks all!  Cheers to unnecessary but fun mods!
Reply #6 on: January 01, 2020, 03:33:23 PM
I'm a big fan of these types types of mods too.
cheers, Derek
Offline fromnowon
Reply #7 on: January 02, 2020, 03:53:44 PM
I'm curious how and where you will decide to mount the new choke.
Considering this myself;
would be great to see a picture if you get a chance!  Thanks and good luck.
Offline Thermioniclife
Reply #8 on: January 02, 2020, 04:32:09 PM
This is how I did it.
« Last Edit: January 02, 2020, 04:41:15 PM by Thermioniclife »
Offline Kermit
Reply #9 on: January 03, 2020, 02:04:44 PM
I have a piece of sheet aluminum arriving tomorrow.   I intend to cut and mount a sub-chassis using 1" standoffs on three of the power supply screws.   My intention is to mount it below the power supply, rotated 90* from Therm's mounting position.  The lugs on the choke will go front to back, rather than side to side.
Pic attached of me holding it approximately where I intend to mount it, and a mock up of the sub-plate.
I am open to input!
« Last Edit: January 03, 2020, 02:47:19 PM by Kermit »
Reply #10 on: January 03, 2020, 04:19:31 PM
If you start connecting the transformer screws on the bottom side of the amp with metal, you will likely cause some operational issues.  The solution is to either use nylon standoffs or use a piece of sturdy plastic instead of aluminum.
Offline Pingu
Reply #11 on: January 04, 2020, 12:30:13 AM
Another place too mount is on the side either next to the valve nearest the transformer. Double sided tape to hold the choke to the base plate, I use servo tape, it’s used in radio module aircraft to hold the control servos in place and is incredibly strong. You can then add a small wooden support to the inside of  base if you want more support. Very easy, no cutting or drilling extra holes, insulated from chassis so a small earth required, and much less chance rf from the transformer.
Here’s a good explanation although he has used metal stand offs screwed tho chassis.
https://www.headphonesty.com/2019/04/upgrading-bottlehead-crack-headphone-amplifier/#comment-5889
You  could also add a small mains filter next to the input with a VDR and Rifa x/y either two or three legged cap to smooth the mains even more. Not sure if make a difference but only a few pennies and a friend who knows more than I do always adds one to all his hi fi bits he works on
Martin
« Last Edit: January 04, 2020, 12:38:49 AM by Pingu »
Offline fromnowon
Reply #12 on: January 04, 2020, 06:23:27 AM
Thanks for the pictures!
The picture attached must be the location in the Headphonesty article.
- If you were to attach with tape, I suppose a ground wire would be necessary.
- If the choke is attached with metal stand-offs bolted to the plate, then no ground wire is needed.
Is that correct?
(That Headphonesty write-up is excellent by the way.)
Reply #13 on: January 04, 2020, 07:25:38 AM
Is that correct?
Our preference is to control any potential magnetic eddy currents by isolating chokes and transformers from the chassis plate, then providing a separate ground wire back to the chassis ground lug.
Offline Kermit
Reply #14 on: January 04, 2020, 08:13:28 AM
Thanks all for the input and info.  Revising my plans for mounting...
