No sound in either channel (resolved)
Jimb0 · 5504
Offline Jimb0
on: January 25, 2020, 09:48:36 AM
Just finished building a Crack with Speedball. Voltages checked out okay but I am not getting any sound. I tried using both my laptop and desktop.
« Last Edit: February 07, 2020, 04:37:25 AM by Jimb0 »
Offline Jimb0
Reply #1 on: January 25, 2020, 10:09:02 AM
N/m it's my Modi Multibit that stopped working.
Offline Jimb0
Reply #2 on: January 25, 2020, 10:25:04 AM
Actually yes there is something wrong with the sound. It's very low and I can't get the volume to go up.
Offline Jimb0
Reply #3 on: January 25, 2020, 10:32:01 AM
ok so i'm getting 1.7v at OB and OA
Reply #4 on: January 25, 2020, 03:06:01 PM
At which OA/OB, the big board or the small board?  Are both tubes glowing?
Offline Jimb0
Reply #5 on: January 25, 2020, 06:08:20 PM
Yes both tubes are glowing and OA and OB on the big board
LED's light up on the small board and the two at the bottom but not on the big board
« Last Edit: January 25, 2020, 07:44:06 PM by Jimb0 »
Reply #6 on: January 26, 2020, 06:40:07 AM
What DC resistance do you get between OA and OB and ground on the big board?  As always build photos can help too.
Offline Jimb0
Reply #7 on: January 26, 2020, 02:04:46 PM
OB and OA reading infinity. Ground is reading 40 ohms.
Pics
https://imgur.com/a/eYBPLEj
Reply #8 on: January 26, 2020, 02:51:15 PM
If you pop each wire out of the big board, you can take it all the way out of the amp, then just temporarily solder the 3K resistors onto the end of those wires.  It would be helpful to know if the amp works under those conditions.  Also, are the voltages on the small boards OK?
Offline Jimb0
Reply #9 on: January 27, 2020, 07:35:50 AM
I no longer have any 3K resistors to test it, is there another way? I'll recheck the voltages soon
Reply #10 on: January 27, 2020, 07:40:19 AM
I would obtain a pair of 3K resistors so that you know if the amp is otherwise working without the big Speedball board.  This is what I would do if I had your amp on the bench for repair.
Offline Jimb0
Reply #11 on: January 27, 2020, 08:27:08 AM
Will do PB
Offline Jimb0
Reply #12 on: January 27, 2020, 08:52:13 AM
Do I need the 22.1 KR ½W resistors as well?
Offline Jimb0
Reply #13 on: January 27, 2020, 09:11:12 AM
OA and OB on the small board is 72v
OA and OB on the big board is 2v
B+ is at 217 on the big board
Reply #14 on: January 27, 2020, 10:40:27 AM
You can leave the small board in and just tack the 3K resistors onto the wires poking up that would hold the big board.
