No sound in either channel (resolved)
Jimb0 · 5232
Offline Jimb0
Reply #30 on: February 05, 2020, 09:38:19 AM
Thanks Chris. So both are suppose to be connected to 3U like in the original build without Speedball?
Offline AB2KH
Reply #31 on: February 05, 2020, 10:19:16 AM
JimbO , Yes. Disconnect the left side resistor from the red wire, move the red wire out of the way, or better yet remove it from the terminal lug altogether, It has B+ on it. Connect the resistor lead that you just disconnected and solder it to the same point that the resistor on the right is connected to the black wire (ground).  That should be the non speedball configuration. (Disclaimer) Please do not do any fufther testing of your amp until Paul (whom is the official expert on this Bottlehead Forum) confirms that this is correct, I do not want to be responsible for injury to you or damage to your amp.
Chris
Offline Jimb0
Reply #32 on: February 05, 2020, 10:30:47 AM
Thank you Chris! Will do!
Offline Jimb0
Reply #33 on: February 06, 2020, 08:44:27 AM
PB I went ahead and tested it and getting 18v at 9 and 9v at 7 now
Reply #34 on: February 06, 2020, 09:54:15 AM
I would test it with a different 6080, though it would be super unlikely to get one with two bad halves.  Can you confirm that it doesn't say 6082 on the glass?
Offline Jimb0
Reply #35 on: February 06, 2020, 10:00:21 AM
Sure. My new 6080 comes in tomorrow. Most of the markings have faded away so I can't read it. The brand is National. Here are some pics of it.
https://imgur.com/a/DLFl115
Offline Jimb0
Reply #36 on: February 06, 2020, 01:59:47 PM
6080 tube arrived today. Rechecked voltages. Both 7 and 9 are now reading 105v.
Reply #37 on: February 06, 2020, 02:54:55 PM
Sounds like maybe a 6082 sneaked through somehow.
Offline Jimb0
Reply #38 on: February 07, 2020, 04:36:57 AM
Thanks PB as usual. Everything is working properly now. Cheers!
