Power Transformer Test Issue [resolved]
Jameson · 58914
Offline stuart.mclean
Reply #15 on: September 04, 2023, 07:47:05 AM
Sure.  Here you go ...
Reply #16 on: September 04, 2023, 02:22:47 PM
The alligator clips you have on the power transformer terminals must not touch each other or the fuse will blow.
Reply #17 on: September 04, 2023, 04:30:11 PM
There was a small air gap, but to confirm I added a couple of wires to guarantee separation.  Unfortunately, same result (.034).  The DMM does show continuity across 7 an 8 so I assume the configuration is correct.
I'm using replacement fuses from Amazon (picture attached) if that may be an issue.
Reply #18 on: September 05, 2023, 06:00:19 AM
Set your meter to read Ohms and (with no powder cord connected to the Kaiju and a fresh fuse installed), measure the DC resistance between the chassis and L on the IEC module, then the chassis and N on the IEC module, then let us know what those values are.
Reply #19 on: September 05, 2023, 10:14:08 AM
N = 0L
L = 0L
E = .9
Reply #20 on: September 05, 2023, 10:19:21 AM
Does the fuse hold if you don't have your meter hooked up to the power transformer?
Reply #21 on: September 05, 2023, 10:49:04 AM
No. I saw the flash in the IEC unit and checked - it was blown.
« Last Edit: September 05, 2023, 04:30:41 PM by stuart.mclean »
Reply #22 on: September 05, 2023, 07:06:09 PM
I would pop all four wires off terminals 1-6 on the power transformer and just let them poke up into the air, then be sure a fuse holds under these conditions.
Reply #23 on: September 06, 2023, 12:27:05 PM
Disconnected the 4 wires.  Turned on power for about 30 seconds.  Fuse did not blow.
Reply #24 on: September 06, 2023, 01:55:33 PM
Can you measure the DC resistance between power transformer terminals 1 and 3? Also 4 and 6?
Reply #25 on: September 06, 2023, 02:01:45 PM
Resistance between 1 and 3 is 0.6.  Between 4 and 6 it is 4.5.
Reply #26 on: September 06, 2023, 03:01:19 PM
You'll need to contact replacementparts(at)bottlehead(dot)com and let them know that you need a replacement PT-9.  Be sure to post a link to this thread which helps expedite the process.
Reply #27 on: September 06, 2023, 03:03:41 PM
Thanks!  I'll get that in right away.
Reply #28 on: October 01, 2023, 03:52:07 AM
I received the replacement power transformer (PT-9) - Thanks! - and installed it with new wiring. The new transformer is working well, but I'm getting values that are very slightly outside tolerance:
PT Leads 7 & 8: 200 [manual states 190 +/- 5%]
            10 & 9: 6.84 [manual states 6.3 +/- 5%]
          14 & 11: 6.84 [manual states 6.3 +/- 5%]
Incoming voltage is 126 so I wired with the > 115 and < 130 instructions.
Does this call for any adjustment to the build?
Thanks for all your help so far!
Reply #29 on: October 01, 2023, 05:04:30 AM
Your powerline is about 5% high and causing the voltages to creep up a little bit, but those are OK.
