Bottlehead Kits
Crack
Question on replacing output caps
A Jedi
4277
A Jedi
Full Member
Re: Question on replacing output caps
Reply #15 on:
February 26, 2020, 04:01:15 AM
How long? Not long...a few minutes maybe?
Thanks for the answer. I'll wait longer and measure in the future
Doc B.
Administrator
Hero Member
Reply #16 on:
February 26, 2020, 04:45:26 AM
Make sure the 270K ohm resistor is properly soldered. If it has a bad connection the supply won't drain off. A couple of minutes should be adequate to drain the B+ before poking around if the 270K resistor is working properly.
A Jedi
Full Member
Reply #17 on:
February 26, 2020, 06:13:26 AM
Thank you sir.
Todd R
Full Member
Reply #18 on:
February 29, 2020, 03:17:38 AM
I use Audience Caps. Here's what they say.
https://www.justradios.com/auriINSTALL.html
Bottlehead Kits
Crack
