high voltages at OA and OB [resolved]
mishak · 1802
Offline mishak
on: March 10, 2020, 01:25:58 PM
Hello all.  Just want to say I've loved my BHC the past year, and this amp is pretty wicked!
I purchased it with the SB 1.1 upgrade, and as advised, I used BHC without speed ball for about a year.  I added the small PCB this weekend and used the amp without any issues after "stage 1" of the SB upgrade.  Today I decided to add the larger PCB part of the upgrade and initially the two LEDs on the OB side of the PCB weren't lit up.  The voltages were off, and I re-soldered some joints and then they lit up just fine.  When checking voltages, OA is reading around 115 and OB around 110.  I tried reheating the TIP-50 legs again and added a bit more solder, however the voltages are reading the same.  The amp is working fine currently, but I just want to make sure its OK.   Thank you all in advance.
« Last Edit: March 10, 2020, 02:46:10 PM by Paul Birkeland »
Online Paul Birkeland
Reply #1 on: March 10, 2020, 01:40:03 PM
What are the OA and OB voltages on the small board?  I would suspect that they are a little on the high side, and that may be moving the voltages at the outputs of the big board up a little as well.
It's also worth mentioning that a really, really strong 6080 will show a greater difference in voltage between the OA/OB on the small board and the OA/OB on the big board.
Offline mishak
Reply #2 on: March 10, 2020, 01:42:55 PM
OA and OB on the small board at 85 and 79 respectively
Reply #3 on: March 10, 2020, 01:44:33 PM
Yeah, so that's a little high.  I wouldn't be concerned about what you're seeing.  You have a 12AU7 that's not super fresh (but totally within normal operating specs) and a 6080 that's got strong emission.  The two in concert are pushing those OA/OB voltages on the big board up a little bit.
Offline mishak
Reply #4 on: March 10, 2020, 01:45:36 PM
thank you so much for the prompt reply!
