Speedball issues [resolved]
Droo · 5710
Offline Droo
Reply #30 on: April 27, 2020, 04:50:34 AM
Thank you both so much for the suggestions! I'll definitely try to get better/smoother joints all around and clip whatever leads are still too long. Resoldering the diodes might be a little difficult, but I'll give it a shot, otherwise I'll go with some electrical tape. I want to note that the ones that should not be in contact look like they're in the same plane, but are in fact bent away from each other.
Reply #31 on: April 27, 2020, 05:15:10 AM
Yeah, if I got your Crack in as a repair, I would toss that big PC board and completely replace it.
Offline Droo
Reply #32 on: April 27, 2020, 05:31:36 AM
What's wrong with the board itself? At this point I'm very confused, because it doesn't seem like anything on it is broken, but yet it doesn't work. Should I buy a new speedball?
Reply #33 on: April 27, 2020, 05:56:15 AM
When all the LEDs light up brightly before anything has warmed up in the circuit, the board is not working properly.
You can contact replacementparts(at)bottlehead(dot)com about getting a new big board and associated parts.  You do absolutely need a proper pair of side cutters to trim things down in there too.
Offline Droo
Reply #34 on: May 05, 2020, 08:49:51 AM
It works now, and it sounds great!! However, I'm getting 145 on OA/OB and 250 on B+. Is that a problem? It's dead silent when nothing's playing. I'm using the Raytheon 6080 that came with it if that matters. Thanks!
Reply #35 on: May 05, 2020, 09:46:31 AM
What are all the voltages on the small PC board?  You should not have 250V of B+.
Can you also inspect the solder joint on the headphone jack where the black wires meet?  Sometimes one is loose there and that will make your DC voltages look a little weird.
Offline Droo
Reply #36 on: May 05, 2020, 02:39:53 PM
The headphone jack joints all look solid. One of the LEDs on the B+ side isn't turning on, but the one after it is. I remeasured the big board voltages, and they're actually OA: 116 OB:125 and B+:215. Little board voltages: OA:84, 1A:215 B/AB:0V 1B: 220 OB:79.
Reply #37 on: May 05, 2020, 03:13:32 PM
One LED out on the big board is definitely an issue.  Your small board voltages look good.  B+ on the big board and IA/IB on the small board are all wired together.  You can't have different voltages on these board pads without flaky solder joints at work.
Offline Droo
Reply #38 on: May 05, 2020, 03:30:31 PM
Yeah, I think it went out when I tried to get a better joint on the TIP50. I replaced it and am back up to 235 on B+ and 130 apiece on OB/AB. A weird thing I noticed is that if I tap the input tube, I hear it much more distinctly in the left channel.
Reply #39 on: May 05, 2020, 03:33:05 PM
What's your AC wall voltage?
I strongly suspect your big Speedball board is still not working at all.  The high voltages on OA/OB indicate that the 6080 is drawing nearly no current.
Offline Droo
Reply #40 on: May 05, 2020, 03:47:27 PM
It's around 122 V
Reply #41 on: May 05, 2020, 05:40:32 PM
Yeah, the big Speedball board is not pulling the proper current.  I would suggest a lot more heat on the TIP50 terminals and even the 2N2222 terminals.
Offline Droo
Reply #42 on: May 06, 2020, 08:27:08 PM
So I reflowed all the joints. I'm now getting 203 on B+ and 110/113 on OB and OA. Is this good enough for operation?
Reply #43 on: May 07, 2020, 05:23:23 AM
Yes, that is now a working amplifier.
Offline Droo
Reply #44 on: May 07, 2020, 06:05:12 AM
Awesome. Thank you so, so much!
