George Wright WPL-20
robertod · 9832
Reply #30 on: August 18, 2020, 03:43:22 PM
On the hum pots, you could also glue them just behind the grommet where the blue/red wires poke through from the OT.  I like black RTV for that job, which is available at the autoparts store.
I would not use stranded wire anywhere in those amps.  I would not use bare copper wire anywhere in those amps either.  You should only need a few inches of that wire; it's just to connect the outer lugs of the pot to the filament lugs on the sockets.  You'll need some solid core tinned hookup wire to go from the center lug of the pot over to the rest of the circuit.  I would've sent you some if I'd thought about it, but that didn't cross my mind when I mailed your envelope.
On axial capacitors, there will either be a bunch of + symbols indicating the positive side, or a big fat black stripe that looks like a continuous arrow that points to the negative section.  Another way to triple check is that most of these caps have a crimp on one end of the tubular body, and that is on the positive end.
The film caps and the resistors are non directional parts.
Reply #31 on: August 18, 2020, 03:43:51 PM
Also, it goes without saying, do one amp at a time!!!  Been there, done that!  Don't want to do that again!
Offline robertod
Reply #32 on: August 18, 2020, 05:45:56 PM
I understand the negative and positive sides of the cap.
Yes, for sure one amp at a time.  Thanks for answering all my questions.  I never worked on amp(s), replaced/upgrade de-solder/solder.
That is why soooo many questions.
Thanks!!!!
Congrats on the Moreplay pre-amp!!!  Another solid build from Bottlehead!
« Last Edit: August 18, 2020, 05:54:19 PM by robertod »
Rega P6
George Wright Sound WPL20 preamp with phono
George Wright Sound 2A3 Mono Blocks 3.5 watts
Audio Note M-1 Phono Pre-Amplifier
Jager Speakers
Offline robertod
Reply #33 on: August 20, 2020, 12:17:06 PM
As I work on the mono blocks, I have noticed a goldish color around the different connections.
Can this be cleaned or should I leave alone.  Also I noticed the new capacitors (silver) have a plastic wrap on them.  Should I remove it?
Rega P6
Jager Speakers
Reply #34 on: August 20, 2020, 01:01:09 PM
The goldish color on the connections would be flux from the solder.  I would just leave it there, as it isn't all that easy to clean off, and when you do it will just migrate down into that chassis.
The plastic wrap on the connectors insulates the metal body of the caps (which is also the negative connection of the cap) from coming into contact with anything.  I would not remove the plastic wrap under any circumstances.
Offline robertod
Reply #35 on: August 20, 2020, 01:57:36 PM
Thank you for the response.  I'm learning every day.
Rega P6
Jager Speakers
Reply #36 on: August 21, 2020, 04:49:32 AM
George's vintage surplus solder.  ;)
Offline robertod
Reply #37 on: August 24, 2020, 07:06:11 PM
View Profile Email
Re: George Wright WPL-20
« Reply #17 on: August 09, 2020, 04:19:14 PM »
Quote
On the 4 pin side of the blue cap, there will be a resistor to ground.  I can't see it in the photo, but if you provide the value I could give an educated guess as to what value it might be.
I copied your post that I did not answer. I have attached a pic showing the resistor your referenced that needs to be grounded. I hope the pic helps.
The hook up wire is on its way, then I can continue the mods.
Rega P6
Jager Speakers
Reply #38 on: August 24, 2020, 07:23:39 PM
That would be this resistor.  You could probably just call it good with the hum pots and some fresh caps.
Offline robertod
Reply #39 on: August 25, 2020, 04:13:51 AM
Ok,  so I'm good to go with the other mods, thanks for clearing that up.
Rega P6
Jager Speakers
Offline robertod
Reply #40 on: August 25, 2020, 06:36:17 PM
Picking up hookup wire tomorrow.  This will allow me to finish the hum pot.  The caps have beeen upgraded.  The two new resistors have to be installed.  If I install the two resistors should the resistor you mentioned in the above post, need to be grounded?  And how do you ground the resistor?
Rega P6
Jager Speakers
Reply #41 on: August 26, 2020, 05:34:41 AM
If you are going to replace any resistors, you pull the one out you'd like to replace, then put the new one in exactly where the old one was (connected to the same terminals).
Offline robertod
Reply #42 on: August 26, 2020, 09:08:23 AM
Ok gotcha, I do not have to ground the the resistor you mentioned earlier.
Thanks.
Rega P6
Jager Speakers
Reply #43 on: August 26, 2020, 11:37:22 AM
Thanks.
The resistor I mentioned earlier would go between the grid of the output tube and ground.
Offline robertod
Reply #44 on: August 26, 2020, 11:52:21 AM
Could you send pic how it should be done.
Rega P6
Jager Speakers
