Bottlehead Kits
Crack
New Crack build, high voltage on T5 and T9
[email protected]
4571
3
[email protected]
Jr. Member
Re: New Crack build, high voltage on T5 and T9
Reply #30 on:
June 30, 2020, 02:17:58 PM
Got it functioning properly finally (sounds great!).
It is a loose connection in the octal socket. I don't yet know if it is the socket itself, the tube or bad connections/solders on the pins.
It is presently stable, though, which is a relief. Are better octal sockets available which are recommended?
Craig Gulla
Paul Birkeland
Global Moderator
Hero Member
Reply #31 on:
June 30, 2020, 08:35:52 PM
There are many octal sockets that I don't recommend, like the teflon ones, PC pin ones, etc. You can get the same socket with solder cups, though I like how easily the fork pins in the ones we use can be tensioned if necessary.
[email protected]
Jr. Member
Reply #32 on:
July 01, 2020, 05:37:24 AM
Ah, good to know! I'll explore tensioning if need be.
Craig Gulla
3
Bottlehead Kits
Crack
