Progress Update [resolved]
Darkblade48 · 4838
Offline Darkblade48
Reply #15 on: August 06, 2020, 10:15:57 AM
Sorry for the incessant questions, but I just want to be sure of what I'm doing.
I should be cutting and removing the drain wire that goes from IEC ground to chassis ground (circled in red)
I am guessing the wire that connects the A-side choke to chassis ground (blue) can stay where it is, and does not need to be hooked up directly to the IEC ground?
I also assume that the other wires are fine where they are?
Reply #16 on: August 06, 2020, 12:49:24 PM
Yes, just replace the wire in red with the antiphase diodes.  You may find it easier to clip that wire in the middle and then bend each end into a loop, then attach the diodes to those.
Offline Darkblade48
Reply #17 on: August 06, 2020, 04:29:12 PM
As always, I have to say thank you for all the help and speedy responses, Paul!
The pair of diodes worked wonderfully. Absolutely black background now. Now to enjoy some more music!
Reply #18 on: August 07, 2020, 05:17:49 AM
I'm glad that took care of it for you.  As always, we are here if anything else comes up.
