Iron upgrade
patm · 4861
Offline patm
on: November 14, 2010, 05:17:50 AM
I have the iron upgrade and I have one question. PJ says
"The same goes for the output transformer primary; the dot goes to the parafeed cap and the other terminal goes to the middle terminal of the hum pot. The secondary is marked "c - 8 - 16" and C is the black output binding post. The wire from the red binding post goes to 8 or 16 depending on what impedance your speakers are."
My question concerns the output primary. There are two terminals, one marked PLATE and one marked AC GROUND. Am I correct in assuming that PLATE goes to the parafeed cap and AC GROUND goes to the middle terminal of the hum pot?
In the beginning there was nothing, then it blew up!
FP III, Paramount 300b (Takatsuki TA-300B), both with Mundorf S/O caps, Mikes iron, HFBG Eros,Oppo 103,Rega RP6 2m black ,Vaughn Triode JR II
Reply #1 on: November 14, 2010, 07:32:51 AM
Yes, you are correct.  The parafeed cap is taken from the output tube plate and on the other side  of that cap you have your transformer primary dotted lead.  The other connection keeps the cathode resistor and capacitor out of the transformer primary.
Offline patm
Reply #2 on: November 14, 2010, 08:56:29 AM
Thanks Grainger, Time to heat up the iron.
