0.1uf boards caps
Alby0521 · 4702
Offline Alby0521
on: August 14, 2020, 03:43:25 PM
Hello
Is it worth to upgrade the 0.1uf caps on the 2 pc boards? Anyone had good experiences on this upgrade? If so what good brands can be used which don’t brake the bank?
I already got the 10uf, 100uf and 0.1uf(the one attached to the terminal strips) for a future upgrade but I see  that some people upgraded the 0.1uf caps on the boards too so I was interested in any experience.
Thanks in advance.
AB
Offline Alby0521
Reply #1 on: August 16, 2020, 10:24:46 AM
Hello,
No one had success with the spoken upgrade?
Best
AB
Offline grufti
Reply #2 on: August 16, 2020, 10:42:15 AM
The questions that you might want to ask yourself is: why is swapping one capacitor for another always an upgrade? What is the function of that capacitor in the circuit?
Offline Alby0521
Reply #3 on: August 17, 2020, 05:01:00 PM
I’m not completely sure what that cap does that’s why I’m asking here as I saw some people changing caps in that position.
AB
Reply #4 on: August 17, 2020, 06:40:45 PM
I haven't heard huge differences in caps there.  I have had to do some repairs where huge 0.1uF caps have destroyed the PC board because they are too heavy.
Reply #5 on: August 17, 2020, 07:12:10 PM
The 0.1uF cap on the shunt regulator, along with it's associated resistor, stabilizes the feedback loop to prevent oscillation and/or ringing. Don't change the values! It's been a long time since I did the analysis, but if I recall correctly the instability happens at around a megaherz, which would lead sometimes to very hard-to-trace, unpredictable effects.
If you do change the cap, use something physically smaller to minimize RF sensitivity. Don't use Mylar without re-doing the stability analysis because Mylar develops a significant ESR at radio frequencies. Maybe something like mica, or NPO (C0G) ceramic.
Offline Alby0521
Reply #6 on: August 17, 2020, 07:33:34 PM
Hello Paul and Paul
Very clear thank a lot.
I’ll let the caps be on that position.
Best
AB
