300B Stereomour
Thoburn · 7117
Offline Thoburn
on: November 17, 2010, 03:50:25 PM
Just curious, but I was wondering if the Stereomour would ever have a 300B option?
Dynavector DV-20X2L > VPI Scout II > Musical Surroundings NovaPhonomena
Mac Mini > USB DACiTx
Stereomour > Lowther Medallion DX4 and Rythmic Subs
Monster Power HTS3600
Reply #1 on: November 17, 2010, 07:39:24 PM
I have a couple ideas in mind ... it's a bit tricky to get the higher voltage needed, but it IS under consideration...  :^)
Offline Thoburn
Reply #2 on: November 18, 2010, 03:41:53 AM
Very cool. I have a DIY 5 inch back loaded, rear firing horn project in mind. It would be about 94 Db/W/M, so I think the 300B would be a good match.
Offline Dr. Toobz
Reply #3 on: November 18, 2010, 04:02:12 PM
Without changing transformers or squeezing in one just for filaments, wouldn't one be limited to a 2.5v 300B?
Reply #4 on: November 18, 2010, 05:25:17 PM
Heh-heh! No, I have planned ahead - the 2.5v winding is quad-filar, two independent bifilar windings. I can ask the supplier to make a bifilar winding of two independent single windings, which will supply 5v at 1.25 amps. A very small change to an existing design. Hum might be 4-6dB greater, so we'll have to try it and see - like I said, I have some ideas but they need to be tried out.
The good news is that we can do the experiments with a 2.5v 300B, and not mess with the power transformer before we know whether we have a good basic design.
There are a few more things in the pipeline before we get to this, though.
Offline Dyna Saur
  • Yippie-Ki-Yay....
Reply #5 on: November 19, 2010, 01:18:01 PM
The J/J 2A3-40 is very close to being a 300B with a 2.5V filament.  At the Stereomour's  existing "2A3" B+ voltages and currents, it would still behave more as a 2A3 would.  At those voltages / currents, the 2A3-40 should last a VERY long time (the "-40"  refers to the 40 watt plate dissipation rating, as compared to 15W for a 2A3).    I've put the 2A3-40s in Paramour IIs and they sound very good, though they do not deliver any higher power output.
HTH
/ed B in NC
ed brown
