Need to buy additional resisters - what stores are good?
bsadowski · 1837
Offline bsadowski
Hi, I am building an Eros and are there specific stores where I should buy additional parts (specifically the Dale 470k ohm resistor 4703f)?  I accidentally used the 4703f where I was supposed to use a 4702f so clipped the ends and can no longer use the 4703f in the appropriate place. So I need to buy 2 more of them.  But not sure if any 470k ohm resistor will work or if some have better quality than others.
Bryan
Reply #1 on: November 22, 2020, 01:11:16 PM
Strip back a piece of wire and solder it onto the resistor to make it longer.
Failing that i am sure BH will help you out if you email them..
Offline Colonl_Charisma
Reply #2 on: November 22, 2020, 01:42:27 PM
Digikey is the place to go for these types of products. Great prices too. I could not find Dale resistors at 470K ohms, but I was able to find another manufacturer. I'll link below.
470K ohms resistors = https://www.digikey.com/en/products/detail/yageo/CFR-25JB-52-470K/2210
My Google searches could not really turn up any Dale 470K ohm resistors for sale other than on Ebay. It's not that I don't trust the sellers, but they are only selling them in bulk (pack 100+ for $30).
« Last Edit: November 22, 2020, 01:49:53 PM by Colonl_Charisma »
Ross
Fiio K11 R2R --> Bottlehead Crack --> HD600
Reply #3 on: November 22, 2020, 02:44:59 PM
+1
Edit: but if you need to replace it b/c there's not enough lead left to solder to, or you simply prefer to replace it, you can order it online here: http://www.mouser.com/Vishay/Passive-Components/Resistors/Film-Resistors/Metal-Film-Resistors-Through-Hole/RN-Series/_/N-7gz41Z1yzvvqx?P=1yzbpodZ1z0wkq1Z1yzbppyZ1z0wjc0Z1yzveaxZ1z0zls5Z1z0yhc6&Keyword=4703f&FS=True
Note: you'll need to choose between 1/4W and 1/2W - I'm not sure which one the Eros uses. But you can always use a 1/2W in place of a 1/4 (but not the other way around).
You could also try calling an electronics hobbyist shop, if there's one near you, to see if they have it in stock -- if they do you won't need pay 20X the purchase price for shipping.
cheers, Derek
« Last Edit: November 22, 2020, 03:00:38 PM by Deke609 »
Offline Thermioniclife
Reply #4 on: November 22, 2020, 05:15:23 PM
Mouser is my first go to.
Offline bsadowski
Reply #5 on: November 23, 2020, 11:57:15 AM
thanks for the quick responses!  I will try soldering on a piece of wire first.  If that doesn't work then I'll go to mouser and find the right one to order.
Bryan
