New Build resistance checks
cycogod · 5795
Offline cycogod
on: December 08, 2020, 03:53:02 PM
everything reads good but on terminal 2 i get 19.5 m ohms . .
i believe this is a star value...does this seem ok. ?
thanks
Reply #1 on: December 08, 2020, 04:46:23 PM
Terminal 2 is wired to terminal 4, B2, B5, and 13.  Do you get the same resistance reading on all those terminals?
19.5 mega-ohms is 19,500,000 ohms, which would be OK.  19.5 milli-ohms is 0.019 ohms, which will cause some problems.
Offline cycogod
Reply #2 on: December 08, 2020, 05:23:37 PM
terminal 4 reads 794 k
b2 - 0
b5 - 0
13 - 0
i believe the numbers were M ohms,  meaning mega. so should be ok. sound correct?
Reply #3 on: December 08, 2020, 05:26:52 PM
Oops, I saw "Crack" not "Crack-a-two-a".
14L should show the same DCR as 2L.
Offline cycogod
Reply #4 on: December 08, 2020, 05:35:18 PM
yes they do
Offline cycogod
Reply #5 on: December 08, 2020, 05:37:40 PM
feel pretty good. i'll read voltage tomorrow. thanks
Reply #6 on: December 09, 2020, 06:15:29 AM
Yes, then you are probably seeing 19.5 million ohms.
