Loud buzz in Right Ear and static in left
shoto1699 · 1694
Offline shoto1699
on: December 21, 2020, 09:12:09 PM
So my Bottlehead Crack has the right voltages but there's static coming through my left ear's headphones and a loud buzz in the right. It was working fine earlier but when I turned it off later on and turned it back again it came up but only went away after my monitor shut off for a second and then came back later on. Any ideas? I reheated everything already. The buzz came after I reseated the tubes again.
« Last Edit: December 21, 2020, 11:32:10 PM by shoto1699 »
Reply #1 on: December 22, 2020, 05:23:15 AM
Can you post photos of your build?
Generally this kind of issue would be a loose solder joint in the amp, and often time we find that new builders are a little timid when it comes to applying adequate heat to get the solder to flow out all the way.
Offline shoto1699
Online Jameson
  • Intern in Chief
Reply #3 on: December 22, 2020, 08:53:20 AM
Might not be related but I'd pick up one of those ALPS PCBs on eBay instead of soldering to the potentiometer pins like that. Much easier and more reliable.
Jameson O'Guinn
Managing Partner
Offline shoto1699
Reply #4 on: December 22, 2020, 09:34:35 AM
Good idea.. it was pretty hard to solder it but I ended up getting it done. I'll check it out
Online Jameson
  • Intern in Chief
Reply #5 on: December 22, 2020, 10:21:18 AM
Jameson O'Guinn
Managing Partner
Reply #6 on: December 22, 2020, 12:00:21 PM
One black wire on your headphone jack does not look to be captured by solder.  If your iron has a temperature adjustment, I would turn it up all the way.  I would also trim back any leads that are poking out.
