220 Ohm at the output
AB2KH · 3569
Offline AB2KH
on: January 15, 2021, 01:44:41 PM
Doc,PB,PJ,
Not having read my copy of Electronics for Dummies could you tell me the purpose for the 220 ohm resistor at the output #2 (or is it) #1 . Does this have to do with output impedance adjustment for bi amping or for sub woofer connection?
Chris/AB2KH
Reply #1 on: January 15, 2021, 01:53:45 PM
It's possible that a little resistance between the outputs could help to prevent interactions between the components you may have connected to each output.  Having said that, I've never actually run into this as a problem, but we use the resistors anyway.  It also makes the jacks much easier to wire together.
Offline AB2KH
Reply #2 on: January 15, 2021, 02:16:22 PM
Paul,
Thank you for your answer.  So in effect it could benefit in the implementation of bi amping ?
Chris/AB2KH
Reply #3 on: January 15, 2021, 04:43:44 PM
It certainly won't hurt if you're biamping.
