Speedball wire guage?
andyh · 2355
Offline andyh
on: January 17, 2021, 09:26:19 AM
What is the gauge of wire in the speedball upgrade kit please.
It's a lot thinner than the crack kit and my stripper wont go that small so curious what to buy.
Thanks in advance.
Reply #1 on: January 17, 2021, 09:34:48 AM
Offline andyh
Reply #2 on: January 17, 2021, 09:50:06 AM
Thank you.
Reply #3 on: January 17, 2021, 10:29:38 AM
You can also use an xacto blade to carefully score the teflon insulation and then pinch it between your fingernails and pull it off. a bit tedious, but perfectly workable if you only have a small number of wires to do.
cheers, Derek
Offline johnsonad
Reply #4 on: January 17, 2021, 11:02:48 AM
I've got a set of Klein standard wire strippers and I've never had a problem with the Alpha Teflon wire.  Someday I'll find an excuse to upgrade to the style PB recommended.
Offline Wplchou
Reply #5 on: January 18, 2021, 02:43:54 AM
Thanks in advance.
After reading this post I realised I did the speedball upgrade with all the wires from the crack which is a lot thicker... Im happy to report it works and no issues so far.
Offline andyh
Reply #6 on: January 18, 2021, 09:46:55 AM
Would make life much easier, wonder what the reason for wire change is.
Reply #7 on: January 18, 2021, 10:00:50 AM
The wire we provide with the Speedball kit cannot be melted or burned with a soldering iron, and this can come in really handy with the installation of the Speedball.
Offline andyh
Reply #8 on: January 18, 2021, 10:19:19 AM
So the standard wire would be ok if you're careful??
Reply #9 on: January 18, 2021, 10:21:48 AM
Yes, if you have enough extra wire from the stock kit, you can certainly use that.
