Help. Can’t get past the power supply test. [mostly resolved]
last lemming · 5310
Offline last lemming
I’ve double checked everything and my solder joints and direction of all components look correct. My test on the power transformer came up correct, but when I test the +6.3v and -6.3v I get 13.2v. What do I do?
« Last Edit: February 23, 2021, 02:19:41 PM by Paul Birkeland »
Reply #1 on: February 22, 2021, 03:06:32 PM
Can you post some photos of the top and bottom of the power supply board?  I would be willing to bet you have some cold solder joints and the regulator isn't doing any regulating.
Reply #2 on: February 22, 2021, 03:29:22 PM
this is where I am so far
Reply #3 on: February 22, 2021, 03:38:25 PM
Those are teeny, is there any way to get something a bit bigger?
Reply #4 on: February 22, 2021, 03:56:05 PM
hope these are better
Reply #5 on: February 22, 2021, 04:22:34 PM
Can you confirm that there's a 1085 regulator on the PC board and not an MJE5731A?
You could certainly reheat all your solder joints, but they don't look like I would expect them to in order to end up with no regulation.
Reply #6 on: February 22, 2021, 04:27:03 PM
Are you talking about the two Cree 1060’s?
Reply #7 on: February 22, 2021, 04:27:33 PM
No, the three legged regulator that mounts to the heatsink.
Reply #8 on: February 22, 2021, 04:29:29 PM
Oh yeah. Yes that is what is on there
Reply #9 on: February 22, 2021, 04:30:33 PM
Would a bad connection at T7, T9 or T11 or T12 do this?
Reply #10 on: February 22, 2021, 04:33:53 PM
I would go ahead and reheat all of the solder joints on that PC board.  You are unlikely to damage anything on there from overheating.
If you have 12V coming out of the 6.3V pads, you power transformer connections are unlikely to be a problem, but the 1085 regulator isn't doing its job.  This could occur due to soldering issues, an MJE5731A swapped in instead of the 1085, or possibly you have a meter that isn't working properly.  To rule out the meter, you can try measuring a 9V battery with it.
Reply #11 on: February 22, 2021, 04:36:55 PM
I pulled the power supply off and retested the transformer. I got 9.2
V on the first test and 144v on the second. I also reflowed the joints. I will try soldering the PS board back on and see what happens
Reply #12 on: February 22, 2021, 04:54:14 PM
Well not sure where to go from here. I’m still getting 13.2v. My meter is good, I reflowed all the joints, they didn’t look bad, but I reflowed them anyway. I also double check the transformer it checks out, so I’m not sure what to do now?
I don’t know enough to know how to trouble shoot.
Can the 1085 be over heated by the solder?  I didn’t really put too much heat on it. I did notice that on each leg on the top side of the board, I used a bit too much solder and each leg had a small ball of solder at the base.  I tried to remove after I tested but really couldn’t get the solder off.
« Last Edit: February 22, 2021, 05:17:04 PM by last lemming »
Reply #13 on: February 22, 2021, 07:59:50 PM
Can you post a photo or two looking at the 1085 and what you're seeing?
Reply #14 on: February 23, 2021, 01:57:33 AM
here you go
