C4S Board LED on and off every 5-10 minutes [resolved]
prtuc2 · 1159
Offline prtuc2
on: February 23, 2021, 07:09:38 AM
Hi guys, I been having trouble with my crack with speedball upgrade for a while. The problem started when I plug in my headphone into the headphone jack like a year ago. So, at first I just spin the headphone cable the cracking sound would go away then every 5 minutes or so the crackling sound would start on again. I didn't have time back then, so I left it be.
A few days ago the new 12AU7 tube arrived, thinking perhaps the tube might have been bad. The problem continues as the new tube was being replaced. Then, I was looking to re-solder some joints near the headphone jack area and the RCA connector. Tighten up the RCA nuts. Problem still remain unsolved and this morning as I was doing some measurement for the amp here is what I got for the resistance values that didn't match the manual:
Terminal 7             2.9k Ohms ----- (OL)
Terminal 9             2.9k Ohms ----- (OL)
B3                        2.9k Ohms ----- (OL)
B6                        2.9k Ohms ----- (OL)
basically, all the 2.9k Ohms terminals in the manual I got OL reading.
Then I took the VDC readings for each terminals
1                          66.1V
2                          170V
3                          0
4                          170V
5                          66.1V
6                          0
7                          95V
8                          0
9                          97V
10                        0
11                        0
12                        0
13                        165V
14                        0
15                        184V
20                        0
21                        206V
Here is the strange parts when I was taking the reading, terminal 1-5 need constantly holding in different positions to get reading then I realized the C4S board led on all 3 boards were not ON. I move the capacitors on terminal 7 or 9 or wiggle the terminal 6-10 strip then the LED came back ON and I retake the values on terminal 1-5 now is just a tap no need to reposition multiple times for a reading.
As I plug in my headphone after 5 minutes the static, crackling sound is back again then I look at the C4S LED on the board it were OFF then I press on the top metal plate at the headphone jack/ volume knob/ input tube area the static went away. If I let my hand off the metal plate static comes back again.
Is it a loose connection or soldering problem? I am kind of confused. Thanks in advance for any inputs everyone.
« Last Edit: February 27, 2021, 08:40:09 AM by Paul Birkeland »
Reply #1 on: February 23, 2021, 07:26:17 AM
If moving the headphone cable around makes a difference, you have a loose connection.  It's ultra common to have a loose wire where the two black wires meet on the headphone jack.
The resistance measurements you took are from the stock Crack manual with 3K resistors.  You will not get a 3K reading on 7/9/B3/B6 with the Speedball installed, that's normal.
The voltages you posted are totally fine and would likely change if you disturbed the loose connection.
Offline prtuc2
Reply #2 on: February 23, 2021, 08:21:10 AM
I recheck the headphone wires everything is solid no loose part. I should say that after I tighten up and re-solder moving the headphone cable around didn't make a different in the crackling sound. Now, only the holding down the metal plates or moving the strip from terminal 6-10 can turn on the LED light.
Reply #3 on: February 23, 2021, 09:50:52 AM
Please reheat every solder joint in your amp other than A3, A8, and the power switch.  You still have at least one loose joint.
Offline prtuc2
Reply #4 on: February 27, 2021, 08:32:51 AM
Thanks Paul, re-solder all the joints seem to fix the problem.
