Distortion in the woofers
oguinn · 15856
Offline oguinn
on: March 19, 2021, 09:24:07 AM
Today in the right channel I started noticing some distortion in the woofers. At first I chalked it up to a scratched record but I noticed it happened on all inputs.
Here's what I've done so far:
  • Removed the Kaiju, which would have normally driven the woofers, from the chain and drove with only the Stereomour II. The issue persisted.
  • Tried multiple inputs. Issue persisted
Here's what I plan to try next:
  • Once the BeePre tubes cool I plan to swap them. I anticipate this will not be the issue. (BeePre tube issue)
  • Swap the crossover boards to see if the problem follows the board. (passive crossover issue)
  • Swap the left and right cables to see if the issue follows the channel (BeePre construction issue/speaker issue)
Anything else I ought to try?
Jameson O'Guinn
Offline oguinn
Reply #1 on: March 19, 2021, 09:36:53 AM
Updates as I get them. Here's what I've done so far:
  • Swap the left and right cables to see if the issue follows the channel. It didn't. That, in my mind, eliminates the BeePre, the cables, and the tubes.
Jameson O'Guinn
Offline oguinn
Reply #2 on: March 19, 2021, 09:50:15 AM
Swapped the crossover boards. Initially no change: distortion and weak output from the right channel. However, after a few seconds the sound kicked in fully without distortion.
This to me sounds like a loose connection inside the cabinet, which sucks since that means I have a new project. I'll wait until it acts up again.
Jameson O'Guinn
Online Paul Birkeland
Reply #3 on: March 19, 2021, 09:50:42 AM
When I have run into this with my Jagers, it has always been a loose banana plug (a loose set screw, not the connector itself).
Offline oguinn
Reply #4 on: March 19, 2021, 09:53:08 AM
I'm satisfied by that explanation for now. Saves me from light surgery.
Thanks, Paul.
Jameson O'Guinn
Reply #5 on: March 20, 2021, 12:09:04 PM
Ditto, and when it happened to me it was at a banana plug in a binding post on the cabinet. Time for me to serve up my rant about cleaning all the connectors in your system once a year.
Offline debk
Reply #6 on: May 23, 2021, 03:10:09 PM
I too had some "distortion"  in the woofers.  The quick disconnects fit very loosely on the terminals of the woofers.  I crimped them tighter on the terminals and the distortion went away.
Debra
Debra K
Eros 2Phono amp
BeePre2, Psvane ACME 300b
Kaiju, Linlai Elite  300b
Rega P6 Ania Pro cartridge
Roon Nucleus
MHDT Labs Orchid DAC
Jager speakers
