Twisted Wires [resolved]
hpleung · 1866
Offline hpleung
on: April 01, 2021, 06:57:08 AM
I am at the point where i made the "green" twisted wires. When soldering the twisted wires, the instructions does not seem to indicate a specific end to connect. Is it the case that for all twisted wires connection, you are free to choose any of the 2 wires in the twisted wire connection?
For example "Using the untrimmed end, attach and solder one wire to B7 and the other one to B8". Does it not matter which wire it is?
Thanks.
« Last Edit: April 07, 2021, 06:17:43 AM by Paul Birkeland »
Reply #1 on: April 01, 2021, 07:04:21 AM
For the green twisted wires, it's not important.
Offline ipetruk
  • Igor Petruk
Reply #2 on: April 07, 2021, 01:10:48 AM
Info for better circuit understanding: green wires go to tube filaments, to heat tubes. It is essentially like hooking up a light bulb, does not matter which way
Crack, Mainline, Pipettes, Subette
