Sparks from 6AS7G tube
Colonl_Charisma · 1698
Offline Colonl_Charisma
on: April 04, 2021, 08:09:12 PM
Tonight, I had a rather scary experience. I powered up my Crack to listen to some music when my Tung Sol 6AS7G started making audible noise and then released sparks inside the tube. This is the same tube that had made some noise in the past, but it stopped after I let it burn for awhile.
I put my old Russian 6AS7G tube in and the amp seems fine. Music is playing normal too.
Could this be due to an issue with my Crack or a tube gone bad?
Ross
Fiio K11 R2R --> Bottlehead Crack --> HD600
Reply #1 on: April 05, 2021, 05:16:20 AM
If the Crack works OK with other tubes, this is likely an issue specific to that particular 6AS7G.
Reply #2 on: April 05, 2021, 05:37:30 AM
Thanks Paul! My Crack has been working well since switching back to my old tube.
Ross
