The Tube Beast at ETF2010
Dyna Saur · 4577
Offline Dyna Saur
  • Yippie-Ki-Yay....
on: December 05, 2010, 08:58:30 AM
A totally different approach to all-triode power. This interesting little triode PPP amp was presented at European Triode Festival 2010 (ETF2010)This is afectionately known as The Tube Beast, it has one hundred 6N3Ps (equivalent to 2C51 / 5670 / WE396A) on four PC boards, each containing 25 tubes, with all sections in parallel.  Just think of each of these four boards as being q really BIG power triode.  The differential driver board contains eight triode strapped EL84s as drivers and cathode followers, directly coupled to the bower boards' grids.  Add in six large toroid transformers and mount it all on a one meter square wooden base (39 3/8 inches on a side).  It is reportedly capable of 100 Watts per channel.
Howzabout a new  Bottlehead Kit for this one ;')   8^)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fwww.diyaudio.com%2Fforums%2Fattachments%2Fclubs-events%2F198458d1290959572-european-triode-festival-2010-tube-beast.jpg&hash=556881a97b5964678426e22cbdfac0c87788982c)
As Will Smith said in "Independence Day", I gotta get me one of these...
/ed B in NC
ed brown
Offline JC
Reply #1 on: December 05, 2010, 11:07:01 AM
Is there a picture or a link somewhere?  I'm not having much luck with the search engines on this one...
Jim C.
Offline paulw
  • 2A3 = Music
    • My Hobby Site
Reply #2 on: December 06, 2010, 03:56:05 AM
link to ETF website
http://www.triodefestival.net/
and is this the 'Beast'?
Paul Williams
Acoustic Signature Challenger (with 3 arms) Entre SUT+Seduction, Smash(out) & Quickie(in again), Paramour II's, 7 Pi Corner Horns or Quad 44, Quad 405-2 & Videoton Minimax GB3.
Reply #3 on: December 06, 2010, 04:29:01 AM
I like the "Warning !  Lightning Bolts" sign on the table.
Thanks for the link!
Offline JC
Reply #4 on: December 06, 2010, 05:24:11 AM
I appreciate it!
I wonder if the WAF on this has a "-" in front of it?
Jim C.
Offline HF9
  • Zynsonix.com
    • Zynsonix.com
Reply #5 on: December 06, 2010, 09:39:08 AM
I hope he's using a matched hundredtet of tubes :)
Offline RayP
Reply #6 on: December 06, 2010, 03:09:19 PM
As I understand it, the tubes don't need to be matched. The idea is that there are so many imperfections, it all averages out. I would imagine each tube has its own cathode resistor however.
A while back I built an amp that had 5 12B4A's per channel and I really liked it. I should drag it out again and have a listen.
ray
ray
Ray Perry
Reply #7 on: December 06, 2010, 05:04:41 PM
As I understand it, the tubes don't need to be matched. The idea is that there are so many imperfections, it all averages out. ...
Some years ago, I made a mathematical model of real-world triode nonlinearity in order to assess the importance of it. The model I chose was to average a large number of triodes in parallel, with the mu of each triode chosen from a normal statistical distribution. It worked quite well, and even allowed me to extract a nonlinearity factor from published curves. The nonlinearity factor I chose was the standard deviation of the distribution of mu values.
