LED and Voltage Issues [resolved]
pickles3201 · 4494
Reply #15 on: May 27, 2021, 08:00:44 AM
That style will work. IIRC it's not exactly the same in terms of linearity, but we used to use them for a few years before PJ discovered that the little square ones are a bit more linear at lower currents. I think. Maybe PJ will weigh in.
The other possibility is to wire both cathodes together (A3, A8) to run through the single LED you have left. You will see that described in many posts in this forum.
Reply #16 on: May 27, 2021, 08:14:02 AM
I live in the UK and I’m struggling to find a replacement which looks like the one which came with the kit.
https://www.mouser.co.uk/ProductDetail/Broadcom-Avago/HLMP-6000?qs=sGAEpiMZZMt82OzCyDsLFG14VY5EtHXv%2FT3fszwBz5E%3D
Offline Fattergator
Reply #17 on: May 27, 2021, 12:42:43 PM
Brilliant, thanks for the help! I have ordered a couple of new ones. I just hope my patience holds out!
The Crack is coming together nicely now. Hopefully I’ll be rocking-out in a few days.
FG
Reply #18 on: July 22, 2021, 10:47:13 AM
I received this kit as a repair and found a solder bridge on one MJE350 transistor.
