Diodes used on tube socket
Applemacman · 3404
Offline Applemacman
Reply #15 on: May 15, 2021, 11:36:28 PM
A3. 14.72 volts
A8. 14.92 volts
Offline Applemacman
Reply #16 on: May 16, 2021, 02:56:55 AM
Anybody hv an answer
Reply #17 on: May 16, 2021, 05:02:50 AM
You need to replace both the LEDs.  Be careful when you solder them, as it doesn't take a ton of heat to damage them.
Offline Applemacman
Reply #18 on: May 16, 2021, 05:41:31 AM
So wouñd that be the reason also why i get no sound?
Reply #19 on: May 16, 2021, 06:43:57 AM
Your amp is not working.  You shouldn't be listening to it.
When you swap out a tube socket or other parts, you need to do a voltage check to be sure the amp isn't working, otherwise you may be sacrificing your headphones to learn whether or not the amp is safe to use.
You need to replace the LEDs and recheck the voltages and let us know if any are still not what they are supposed to be.  If all the voltages check out OK, then you can listen to the amp.
Offline Applemacman
Reply #20 on: May 16, 2021, 07:34:19 AM
Ok ok, im trying to loh in to buy teplacements but my password again is not working. I reset it and not rcvd the email.
Offline Deluk
Reply #21 on: May 17, 2021, 01:38:37 AM
When fitting the LEDS make sure you have some curve or loop in the leads. i.e. don't have them straight and direct to the terminals. They don't like to be pulled about. If it was a wire it would be called a service loop to enable you to remove and refit if needed.
