Cover on shunt regulator 12AU7 tube
Tom-s · 4145
Offline Tom-s
on: May 15, 2021, 06:05:00 AM
Is it ok to use a similar tube socket / cover on the 12AU7 as are already in place for the other tubes?
Or would this introduce unwanted hum?
Reply #1 on: May 15, 2021, 06:05:50 AM
Yes, you can put a shield over it if you like.  The 12AU7 in the Eros runs pretty hot and doesn't otherwise benefit from the cover, so we don't use one there.
Offline johnsonad
Reply #2 on: May 15, 2021, 07:28:34 AM
You can use an IERC tube cooler.  I use these on all of the tubes that can fit them.  They work and theoretically extend tube life by lowering the operating temperature.  Mostly I use them because I like the way they look :)
Reply #3 on: May 15, 2021, 09:01:37 AM
Yes, if you use an IERC tube shield on a socket without the bayonet base it will only be serving as a cooler, not a shield. It is designed to work with a bayonet base and needs to make electrical contact with the chassis thru the base to be effective as a shield.
Offline Tom-s
Reply #4 on: May 16, 2021, 09:58:13 AM
Thanks for all the replies as always.
During assembly this plan  was scrapped. Unfortunately the covers that originally came with the Mainline (the one i planned to use as a fourth), were a different build from the ones provided with the Eros.
So. No cover today.
Awkward angled picture attached.
Offline johnsonad
Reply #5 on: May 17, 2021, 01:48:51 AM
It looks great!  Enjoy!
Reply #6 on: May 17, 2021, 02:35:55 AM
The plate finish looks.
I gotta' say the vents around the tube sockets and the RCA jacks on the 2 really make the kit look as premium as it is.
Reply #7 on: May 17, 2021, 06:00:22 AM
That is "looks great".
Offline Tom-s
Reply #8 on: May 17, 2021, 10:05:21 PM
I couldn’t agree more. These would look good on every Bottlehead kit.
Thanks! I do enjoy the build of all Bottlehead kits. Last few weekends I worked on some Cracks.
I cannot listen to the Eros just yet. Will finish it later this week.
