Metallic gong-like sound through headphones when tapping [resolved]
Tomunizum · 1775
Offline Tomunizum
Hello
When the crack is on only, with headphones plugged in, during the first couple of minutes of it powering up, whenever I tap on / jostle the body of the crack:
I hear a sound like what you would hear if you tapped on a metal hollow object or one that reverberates. It resolves after warm up period.
The crack works perfectly, I have had no issues and it passed all checks in the guide.
I am thinking this is benign and something due to the anatomy of the device but I just wanted to make sure this is not a sign of something that could be or is problematic down the line. Something like a bad joint or bad component placement etc.
Thank you ahead of time to any help that is dedicated to my matter.
Best,
Tom
« Last Edit: June 14, 2021, 11:45:22 AM by Paul Birkeland »
This is tube microphony.  It's benign and can be ignored.
Offline Tomunizum
Thank you much for the quick reply Paul.
This resolves my issue.
Best,
Tom
