Which turntable?
Jameson · 4052
Offline Jameson
  • Intern in Chief
Reply #15 on: September 22, 2021, 09:23:35 AM
Is this the Sowter SUT you recommend (with threaded grommets): 1990 1:10/1:20 Low Z Cartridge Transformer
Jameson O'Guinn
Managing Partner
Reply #16 on: September 22, 2021, 10:08:19 AM
Yes, 1990s wired for 1:20 should be OK.  If you're using that cartridge on a Rega arm and you experience hum, let me know, as there are some mods that can be done to separate the shield and signal cold in the tonearm wiring.
Offline Jameson
  • Intern in Chief
Reply #17 on: September 22, 2021, 10:13:22 AM
Thanks PB. Still in the research stage. Considered going with a P6/Ania but wasn’t factoring in the $350ish extra for the SUTs. Probably be a couple months.
Jameson O'Guinn
Managing Partner
Reply #18 on: September 22, 2021, 10:20:44 AM
You could get a P6 with a MM cart, then put the Sowters on order and enjoy the table while they are made.  It will take some time to get them!
Offline Jameson
  • Intern in Chief
Reply #19 on: September 22, 2021, 12:11:22 PM
Picked up a demo unit Rega P6 with the MM cartridge. I can wait to upgrade to the MC and SUTs later. Thanks for the advice.
Jameson O'Guinn
Managing Partner
Offline Jameson
  • Intern in Chief
Reply #20 on: September 30, 2021, 05:52:27 AM
Rega P6 is in. Great sounding table! Good match with the Eros 2 - at least with the MM cartridge. I really thought that Schiit turntable sounded great, but this is much better.
Jameson O'Guinn
Managing Partner
