Which turntable?
oguinn · 3801
Offline oguinn
on: July 29, 2021, 07:11:28 PM
I like my Schiit Sol a lot, but it’s gone out of production and I’m thinking about offloading it to defray the cost of something I can get replacement parts for reliably in the future. With that said, what turntables do people like for about $1,000? I have an Eros 2. I assume that cartridge is a more important consideration, but am interested in thoughts from this group.
Currently thinking a Rega P3.
Jameson O'Guinn
Offline ScottAstroNut
Reply #1 on: July 30, 2021, 02:47:02 AM
+1 on the Rega P3.
It's a great table with plenty of upgrade options.  Mine worked super with the Elys cartridge and the Eros 2. I liked it so much, in fact, that I eventually upgraded to a P6. Count me a Rega TT fan.
Scott Burgess
BeePre 2, Kaiju, Eros 2, Rega P6, Rega Apollo CD player, Bryston BDA-1 DAC, Bryston BDP-1 streamer, Jager speakers, Mainline and Crack for headphones.
Reply #2 on: July 30, 2021, 03:55:25 AM
What Scott said about the P3.
Like everything in this (and every?) hobby most brands have their champions and detractors, comes down to trusted reviews, personal taste and more than a little faith.
Sounds like the Sol is the Schiit though, you will give up a lot of adjustment ability.
Offline oguinn
Reply #3 on: July 30, 2021, 04:31:08 AM
Honestly I think I’m ok with that. I moved the turntable earlier this year and had a raft of adjustments I had to make just to get it back in shape, so something a little more… idiot proof… isn’t necessarily a downside.
I’m reading that with the upgrades for the P3 that it might be worth just saving up for the P6 and getting that instead. Thoughts?
Jameson O'Guinn
Reply #4 on: July 30, 2021, 05:21:50 AM
The P6 comes with the Neo PSU, a $400 upgrade from the P3 on its own. Same tonearm with SS counterweight. I believe the sub platter is also different.
I've done the aftermarket sub platter and counterweight mods to my P3.
Reply #5 on: July 30, 2021, 05:32:46 AM
I would not recommend the Rega options if you plan to use a moving coil cartridges in the future.  They use unshielded cables leaving the tonearm and send the earthing connection through one of the signal cables, so you may run into issues trying to use step-up transformers in the future.
Occasionally I see used LP-12s and some VPI models around here for sale for around $1000.
Offline oguinn
Reply #6 on: July 30, 2021, 05:46:48 AM
Thanks Paul. I thought I recalled seeing something about Rega table issues on here recently. I’ll check those ones you mention out as well
Jameson O'Guinn
Offline Chris H
Reply #7 on: July 30, 2021, 07:26:24 AM
That may have been me with the suspected issues on the Rega turntable with MC cart.
In the end was able to rule out the turntable.
I upgrade from RP3 to RP6 then P8.
If I am honest, I think the RP6 was the sweetspot though it went to help fund the P8.
Now I have the P8 I will keep it but I suspect (know) I would have been happy keeping the RP6.
I still have the RP3 in another room and it is a great turntable.
Worth the upgrade to Elys.
Both RP3 and RP6 (now P3 and P6) were a lot less fussy than the P8 but I suspect that is down to the MC cart.
I will say that I found the change to Eros made a big improvement in sound.  I don't know what the terminology is but it is a much easier listen.
Found the Rega phonos could be a little harsh/trebly/fatiguing on some music.
Improved with cables as it happens (which changed my view on impact of cable) but all solved with the Eros.
Hope this helps
Chris
Offline oguinn
Reply #8 on: August 21, 2021, 12:04:28 PM
Does anyone have experience with MoFi tables? I listened to an Ultradeck in a store today, and it sounded pretty good (I brought my HD800S to get as close to at home as possible) but was listening on a McIntosh amplifier. Wondering how it matches up with Bottlehead gear, and whether MoFi stuff holds up over time.
Jameson O'Guinn
Offline debk
Reply #9 on: August 22, 2021, 03:35:14 AM
I am using a Rega P6 with a MC (Ania Pro) cartridge with no issues
Debra K
Eros 2Phono amp
BeePre2, Psvane ACME 300b
Kaiju, Linlai Elite  300b
Rega P6 Ania Pro cartridge
Roon Nucleus
MHDT Labs Orchid DAC
Jager speakers
Offline kcleveland
Reply #10 on: August 27, 2021, 02:28:04 AM
++1 for Rega TTs. I've owned a used P5 that got severely pimped over the years (every Groovetracer mod available) and then upgraded to a used RP10 which is probably the "final" table for me. Rega is also a great company to deal with. That RP10 had an issue with the motor controller and the local representative in TX replaced the entire pc board gratis despite being out of warranty and not being the original owner. Very pleased indeed. I now use the Rega Aphelion2 cart (just had to see what Rega's top of line sounds like and it's magnificent). Also, love Rega carts because mounting is a breeze with the (3) point/screw setup mated to Rega arms. For easy plug-and-play and great sound it's hard to imagine better than Rega.
Offline oguinn
Reply #11 on: September 22, 2021, 08:55:18 AM
Deb - did you have to install a step up transformer to use the Ania?
Jameson O'Guinn
Reply #12 on: September 22, 2021, 09:10:03 AM
Deb is currently in the Black Rock Desert launching rockets so she may not respond right away.
Offline oguinn
Reply #13 on: September 22, 2021, 09:16:03 AM
Oh gosh, yeah, that sounds way more awesome than responding to a forum post.
Doc - would you go with SUTs with these specs: Nominal output voltage 350μV (.35mV)
Jameson O'Guinn
Reply #14 on: September 22, 2021, 09:21:56 AM
0.35mV isn't enough for an Eros.  You'd want to add SUTs.
