What Amp Are You Using With Moreplay?
Cary · 7136
Offline David Joiner
Reply #15 on: January 07, 2022, 07:07:36 PM
Setup:
Music Streamer: Bluesound Node2i streaming Tidal
DAC: Schiit Bifrost 2
Pre-amp: Bottlehead Moreplay
Power Amp: Schiit Aegir
Speakers: Zu Audio Dirty Weekends
Apparel: Bottlehead Baseball cap
Sound is superb!
Offline marioed
Reply #16 on: January 20, 2022, 04:26:27 AM
I've got my Moreplay connected to my Crack with Speedball and a Decware SE84UFO amp into a pair of Omega Junior 8 XRS speakers. Using some new production Mullard 6V6GT's at the moment but have a selection of 6K6 tubes coming in tomorrow that I'm looking forward to trying.
Regards,
Mario
Offline jlizaso
Reply #17 on: April 14, 2022, 04:40:47 AM
I am using mostly my class A Pass DIY amps.  ACA, F4 and Aleph J.
Jun Lizaso
Audio Enthusiast
Offline Tubegopher
  • Don Palmer
Reply #18 on: April 14, 2022, 09:42:17 AM
Setup:
Sound is superb!
Hi David, I am no doubt older than you at 71, but I have been into audio for many years. Back in the 70's, I managed a high end stereo store called Magnolia Hi Fi. I ran the original Magnolia village store. Point being I am "old school" on some of the newer items today. I am wondering if you can let me know how you use your Music Streamer: Bluesound Node2i streaming Tidal? I do stream from my phone to my system with a dragonfly DAC in between currently, but are there advantages to this Node 2i? I am in the dark. Thanks, Don
Offline nipsy
Reply #19 on: May 10, 2022, 06:13:15 PM
I've hooked the Moreplay into my Decware ZKIT 1. As I primarily play vinyl, I use the ifi Zen phono stage. The music is magically coming out of a pair of Klipsch Heresy 1 speakers. The Moreplay was such an improvement, I'm considering building an Eros 2.
Offline RANGE DOG
Reply #20 on: May 29, 2022, 09:07:23 AM
Dared monoblocks
Offline mosquitorojo
Reply #21 on: May 02, 2023, 04:52:06 PM
Setup:
Sound is superb!
Hi David,
I have my moreplay hooked up to a Carver CM1090 amp (with the preamp bypassed), and I wanted to try an aegir power amp. I have a pair of psb imagine x1t speakers, which have a sensitivity of 90db and are 8 ohms. Do you think the aegir could run my speakers?
Cheers!
Mauro
Offline hmbscott
Reply #22 on: May 02, 2023, 05:50:19 PM
Two amps, a Nobsound 6P1 (class-A SET all signal-path caps upgraded) & a pair of ACA's configured as mono blocks and driven using the balanced inputs. The amps drive the speakers through an A/B switch (Douk Audio VU3).
My system setup:
Ortofon 2m Bronze              Airplay
U-Turn Orbit Theory          WIIM Mini
        Eros 2                     Aries II DAC
                     Moreplay > second out > Crack + Speedball > HD 650
                       Main out
                            V
                 Schiit Lokius eq
      SE out                        balanced out
         V                                    V
Nobsound 6P1                ACA Mono Blocks
                    A/B switch
Hsu Research ULS-15 MK2 subwoofer
DYI DML panel speakers
Sounds amazing and has been super fun to build!
Scott
[Ortofon 2M Bronze > U-Turn Theory > Eros II] & [iMac via USB > Denafrips Ares 2] >> Moreplay >> Schiit Lokius EQ >> Stereomour II >> Hsu ULS-15 Sub >> homemade DML Speakers
Offline hddeluxe1
Reply #23 on: May 02, 2023, 07:10:08 PM
  I'm using the Moreplay with 6v6 cv 509 coke bottle tubes with
  the Reduction phono preamp with integration upgrade.
  A Fluance RT85 with Ortofon 2M blue running through a pair of
  KT 88 monoblocks by Quicksilver through a pair of
  Klipsch  Forte II.
Joe "Pug" Stricker
 Moreplay preamp with 6v6-cv509's
 Quicksilver KT-88 monoblocks
 Fluance RT-85 TT with Ortofon 2M Blue
 Teac A2300S RTR
 Klipsch Forte II's
Offline adeep42
Reply #24 on: May 03, 2023, 04:46:09 AM
Elekit TU8600
Offline dth31
Reply #25 on: May 04, 2023, 06:22:11 AM
Heavily modified DIYHiFiSupply 300B monoblocks
ANK Audiokits EL34 monoblocks
Bottlehead and Paul Birkeland-modified Paramount 2A3s
AudioNote Kit 4 AN/E speakers
Offline stuart.mclean
Reply #26 on: May 05, 2023, 07:20:13 AM
AnalogEthos Legendarium -> Tekton Lores
I’ll be starting my Kaiju build as soon as the chassis comes back from powder coating
Offline timindq
Reply #27 on: May 07, 2023, 11:01:24 AM
I'm feeding a Benchmark AHB2 amp. The Benchmark has XLR input only so I fabricated some cables to fit. Source is a Lumin D2 with an excellent volume control so I rarely adjust the Moreplay's volume knob. Turntable is on permanent vacation.
Source: Lumin D2 with SBooster power supply, 2tb SSD attached to Lumin, Pre: Moreplay, Amp: Bryston 2bSST, Speakers: Joseph Audio RM22XL. Setup in large, well treated dedicated listening space.
Offline Rockyhill
Reply #28 on: September 15, 2023, 01:38:42 AM
I'm considering a Moreplay to pair with my Dynakit ST-35.
I believe this will be compatible for impedance matching:
Moreplay Output impedance: less than 3.2Kohms at all levels. For 1V in/1V out, 2.1Kohms.
ST-35 INPUT IMPEDANCE:        500K OHMS
500/3.2 = 156.25
I understand a ration of 10-1 is an absolute minimum with 50 to 75-1 preferred.
Is this a good pairing?
Rob M
Reply #29 on: September 15, 2023, 04:30:36 AM
Yes, that's fine.
I'll just note that a typical SET amp drives a speaker with an impedance ratio of around 3:1 and sounds fine - so 10:1 is more nearly overkill than an "absolute minimum," at least in some cases.
