Crack Build: Resistance check Terminal 22 [resolved]
ChickenBeak · 2215
Offline ChickenBeak
on: September 23, 2021, 10:19:29 AM
I just finished a Crack build and it passes all resistance checks except for Terminal 22 (open/no connection). This is the transformer mounting screw so there's no soldering to show.
This build passed the initial power test and glow test.
« Last Edit: September 23, 2021, 10:50:41 AM by Paul Birkeland »
Offline Thermioniclife
Reply #1 on: September 23, 2021, 10:33:30 AM
That would indicate no connection to the transformer end bell. Try tightening that screw down a little more. Do the other two screws show continuity to ground? they should.
Offline ChickenBeak
Reply #2 on: September 23, 2021, 10:38:34 AM
Thanks. I removed and degreased the screw, and then reinstalled it (tighter). It's working now.
Reply #3 on: September 23, 2021, 11:08:17 AM
Glad you got it sorted. Enjoy the Crack.
Offline ChickenBeak
Reply #4 on: September 23, 2021, 11:15:39 AM
Voltage checks passed on the first try. I'm testing now with music and it sounds great!
Thanks again.
