Bottlehead Kits
Mainline
Mainline 6.3V reading
Jimb0
2655
Jimb0
Sr. Member
September 25, 2021, 11:23:30 AM
Hi PB. I just wanted to check if the 6.3v at the power supply is suppose to read around 51v? I have the old manual so it says 6.3v but I just looked at one of the recent posts here that it's suppose to be between 50v and 55v with the newer Mainline models?
Paul Birkeland
Global Moderator
Hero Member
Re: Mainline 6.3V reading
Reply #1 on:
September 25, 2021, 04:27:27 PM
The Mainline 1.1 uses the new Eros 2 power supply board, which biases up the 6.3V supply to +50V, so you'll see about 50V on one terminal and 56V on the other.
Jimb0
Sr. Member
Reply #2 on:
September 25, 2021, 04:33:10 PM
Thanks PB! Those are the readings that I got
Bottlehead Kits
Mainline
