Bottlehead Kits > Moreplay
RCA outputs?
Mulburg:
What are both pairs of RCA outputs for? I’ve only used the pair closest to the power jack.
Paul Joppa:
The second set is for subwoofers, or a headphone amp, or bi-amping, or whatever you wish.
Mulburg:
--- Quote from: Paul Joppa on October 07, 2021, 02:40:14 PM ---The second set is for subwoofers, or a headphone amp, or bi-amping, or whatever you wish.
--- End quote ---
Thank you. I guess I should switch over to the other pair to make sure they work. Bi-amping sounds promising.
El Tel:
--- End quote ---
Hi Paul
I've just finished the Moreplay pre-amp and am interested in doing the crack headphone amp. Obviously I have my sources plugged into the moreplay, would it be a simple case of running a set of leads from the Moreplay outputs to the crack amp outputs ?
Paul Birkeland:
Yes, you can cable up the second set of Moreplay outputs to the Crack inputs. You may find that the volume pot on the Crack needs to be somewhere around 50%-75% rotation to allow for the Moreplay to be used in this way without things being overly sensitive.
Navigation
[0] Message Index
[#] Next page
Go to full version
