Eros Alternate Build Thread
xcortes · 22828
Offline pro_crip
Reply #30 on: March 16, 2011, 02:58:35 AM
I should've been more accurate, I was hoping for a single list of the caps and resistors you decided to go with. Just laziness on my part. Thanks and sorry for any confusion and to doc if I stepped on any toes.
Rich
Richard J Feldman
Tune down, smoke up
Offline xcortes
Reply #31 on: March 16, 2011, 03:14:35 AM
Hey, no need to be sorry for anything! I wish I could have been of more help.
Xavier Cortes
Offline Brillo
Reply #32 on: March 16, 2011, 06:59:10 AM
Xavier,
The AuriCaps fit well enough.  I had to hang them off the back side of the terminal strips, away from the tube sockets.  The cap leads are long, so you can trim them to length.  No noise issues for me at all.  PCX will also match caps to a specified value, not just match pairs (I asked).  Their matching service is reasonably accurate - I was satisfied with the result.  I'd bet they would accomodate if you stressed the importance of a very close match to .01 and .015.  IIRC, the .01uf caps measured around .01035ish and were fairly closely matched.  I was able to pair the .015uf caps to .03074uf and .03084uf.
As for impressions, I'd say there's a slight gain in detail.  I may be more impressed after the caps break in.   Time will tell.
Chris
« Last Edit: March 16, 2011, 09:59:47 AM by Brillo »
Chris
