Mainline voltage checks
Bourney · 4091
Offline Bourney
on: November 14, 2021, 09:04:24 PM
Hi there, first time post from me.
Just finished the build, all resistance checks are OK, but I have 3 out of spec voltages:
BREG (B) = 272v (BREG A is 218v)
KREG (A) = 1.1v
KREG (B) = 2.0v
All other voltages within spec.
I notice I have 2 LED not lit on the A side of the chassis C4S board on the B side of that C4S board. The other 6 LED are lit.
Thanks for any help you can offer.
« Last Edit: November 14, 2021, 11:41:56 PM by Bourney »
Reply #1 on: November 15, 2021, 04:38:24 AM
Are you able to perform the 6C45P biasing procedures with all these issues?
What are the OB/OA voltages on the center PC board?
Offline Bourney
Reply #2 on: November 15, 2021, 09:41:12 AM
Hi Paul,
I can bias the A side 6C45P to 145v no problem.
The B side will not come down below ~212v.
OB voltage = 0.97v
OA voltage = 1.19v
Reply #3 on: November 15, 2021, 09:54:13 AM
I would carefully review the wiring on the 6C45P sockets, paying careful attention that the unpopulated pins are the correct ones in your build.
Offline Bourney
Reply #4 on: November 15, 2021, 05:27:19 PM
Thanks again Paul,
Checked all the wiring to the sockets, all looked fine.
I pulled the 6C45P tubes out, swapped them between sockets, and magically everything tests within spec.
Possibly one tube has a bad leg which is used on one socket but not the other? Otherwise its a mystery.
All good now. Sounds great.
Reply #5 on: November 15, 2021, 06:05:57 PM
That is a possibility, or there's a loose connection that was jostled into making proper contact.
