Page 55 voltage check wrong need help again.
Kurthaudio · 20112
Reply #45 on: December 06, 2021, 08:48:54 AM
That's terminal 5.
I definitely would not have just removed the resistor and arbitrarily replaced it.  That just adds more variables and you weren't able to measure any issues with it.
Offline Kurthaudio
Reply #46 on: December 06, 2021, 09:02:44 AM
You asked to see the other side of terminal 6…… that would be terminal 1.
Here…. Here is a shot of all of it.
Offline Kurthaudio
Reply #47 on: December 06, 2021, 09:07:24 AM
My apologies  for replacing the resistor I didn’t see the harm in it.
I am just trying to get this figured out. This has been going on for a few days now and I’m no further now then I was when I began. I don’t want to sound ungrateful for your help, I am but this is turning into a giant headache. If I didn’t have this amount of money tied up into this I’d of moved on with my life by now.
Reply #48 on: December 06, 2021, 09:14:49 AM
It would be helpful to see the back side of terminal 6.
If you had the configuration still with 0V at terminal 6, I would have next instructed you to measure the resistance to ground from terminal 6.  Now that opportunity is lost.
Are these the 5 lug strips we provided?  Very rarely the 5 lug strips we provide go out of stock and we have to provide alternatives, though it's pretty rare.
Offline Kurthaudio
Reply #49 on: December 06, 2021, 09:20:16 AM
No these are not the stock standoffs.
Reply #50 on: December 06, 2021, 10:10:24 AM
What is this?
To be honest, starting over and using stranded wire and the parts we provide would likely be the best idea.  I hadn't noticed the stranded wire till now, and it is absolutely the kiss of death on builds like these.
Offline Kurthaudio
Reply #51 on: December 06, 2021, 10:27:29 AM
That’s the center tab bent in slightly.
Offline Kurthaudio
Reply #52 on: December 06, 2021, 10:44:46 AM
Could you explain why stranded wire is the “kiss of death” because that same stranded wire is working just fine on socket A
I’d be willing to bet you don’t want stranded wire used in these kits because one could easily have a small strand of wire make a connection where one shouldn’t.?. Something else I’ve been diligent about.
Reply #53 on: December 06, 2021, 10:53:53 AM
Yes, the strands go where you don't want them and the wire doesn't stay where you put it.  It's also both harder to make solid mechanical connections with stranded wire and tougher to move a wire if you don't put it in the right place.
Offline Kurthaudio
Reply #54 on: December 06, 2021, 10:56:14 AM
Ok I just found something that is very important, I switched the wires from the regulator board and the problem followed suite. Now socket a has all the voltage issues socket b had and socket b is working correctly!!!!!
I think this says I have a bad regulator……right?
Reply #55 on: December 06, 2021, 10:58:49 AM
No, please resist the urge to blame parts as much as possible.
A bad regulator will result in not having 6.3V appearing between the output pins on the filament regulator board, is that what you're seeing now?
If one of the wires leaving that regulator board is touching something it shouldn't be, that could cause this problem.
Offline Kurthaudio
Reply #56 on: December 06, 2021, 11:02:55 AM
 Nothing is touching anything it shouldn’t. No Cold solder joints and yes it’s making a sold connection.
Don’t worry I will not change anything g unless you tell me to
They both measure 6.2vdc exactly with nothing connected to them.
However I did notice the tube that has the voltage issue doesn’t get as bright as the one that’s working correctly……
« Last Edit: December 06, 2021, 11:07:58 AM by Kurthaudio »
Reply #57 on: December 06, 2021, 11:07:07 AM
Can you measure the DC voltage of each pair of regulator terminals that feed to the sockets?
Offline Kurthaudio
Reply #58 on: December 06, 2021, 11:11:19 AM
6.2vdc A
6.1vdc B
Reply #59 on: December 06, 2021, 11:39:12 AM
Your regulators are doing their jobs.   This board does not have any reference to ground that will compete with the biasing resistors mounted by each socket, and your resistance readings also seem to confirm that this is still the case.
What I would do next is to pop both pairs of black/red twisted wires out of the regulator board, then measure DC resistance between terminal 4 and each of the four now empty output pads on the filament regulator board.
