BeePre 2 Hum [resolved]
Rosinante · 6325
Offline Rosinante
on: December 25, 2021, 05:54:35 AM
I just completed a BeePre 2 build.  All the tests which are part of the assembly procedure were performed with proper results.  When I connected the BeePre to my amplifier, there was a loud low hum.  60Hz is my guess.
I could hook this up to low-powered gear that I do not care about, in my shop/garage, and conduct some testing.  To see if it is volume-dependent or channel-dependent, etc.  To see if music passes through it.  That sort of thing.  But I also want to avoid damage to the BeePre.
Should I put it on my bench and connect it to a low-powered amp and speakers, and do some testing of audio symptoms?
« Last Edit: December 29, 2021, 10:56:45 AM by Paul Birkeland »
Offline Rosinante
Reply #1 on: December 25, 2021, 06:17:55 AM
I failed to mention:  As the tubes warmed up, and perhaps ten or fifteen seconds after powering the BeePre on, I heard the loud hum and immediately turned it off without touching anything.  I think the volume knob was rotate fully counterclockwise.  I am itching to hook it up again and experiment/gather info about symptoms.  Is this the appropriate next step?
Reply #2 on: December 25, 2021, 06:25:21 AM
How do the DC voltages look? Can you post some build photos?  Can you tell us about the power amp and speakers you tried?
If the volume knob is rotated fully CCW, that completely shorts the output of the preamp, and if there's hum under these conditions, that is a problem that will require attention!
Offline Rosinante
Reply #3 on: December 25, 2021, 07:32:51 AM
It's Jim, Paul.  I mis-spoke:  I now think the volume knob was rotated fully clockwise.  Apparently, the guy who cannot distinguish a BeePre plate from a Kaiju plate also struggles with clock motions.
Here are a couple of pictures.  I am hoping for permission to hook this thing up and gather more information but will absolutely follow your instructions.  And I think you work too hard.  My problem is not urgent.
Offline Rosinante
Reply #4 on: December 25, 2021, 07:36:56 AM
BTW, I checked resistance between the + and - connections at one of the output RCA jacks.  With the volume knob rotated fully clockwise, I saw 9.56 kOhms.  Rotated fully counterclockwise, I saw 1.5 Ohms.
Offline bernieclub
Reply #5 on: December 25, 2021, 07:44:41 AM
Maybe a stupid question, but do you have a source connected? I've had some nasty hum from a disconnected cable.    Merry Christmas!
Bernie
Bernie Zitomer
Offline Rosinante
Reply #6 on: December 25, 2021, 07:48:53 AM
Yes, there were three sources connected.  If I test it again, I will see if the selector switch changes anything.
Offline Rosinante
Reply #7 on: December 25, 2021, 08:35:25 AM
Oops.  I skipped some questions.  The voltages measured during assembly were within spec.  If we need a voltage check somewhere, then tell me where.  As you know, Paul, I have little understanding of electronics but I can generally follow instructions.  The power amp was a pair of Leak monoblocks using EL84s in PP configuration.  Speakers were Klipsch Cornwall.
Reply #8 on: December 25, 2021, 09:10:08 AM
In general I would recommend more solder.
With the volume control turned all the way down and almost a dead short across the output jacks, the presence of hum may indicate issues that do not exist in the BeePre.
Offline Rosinante
Reply #9 on: December 26, 2021, 04:33:37 AM
I may have found the cause.  At least one mistake was made at the selector switch.  Stay tuned.
Offline Rosinante
Reply #10 on: December 26, 2021, 05:50:49 AM
My soldering skills are poor but improving.  Some connections have more solder than others.  All of them are actually connected however, and ought to be functional.  If you feel I should reflow connections and add solder then I will do that.  I am hoping to fix the hum problem first.
To be clear, the resistance measurements I posted were not between two jacks.  They are resistance measurements made between the + and - terminals of a single (right side) output jack.
I found a mistake, and have corrected that.  I had put the wrong wires on terminals 2 and 3 of the selector switch.  I am now tempted to connect this BeePre to a test amp and speakers to see if the hum problem is addressed.  Any concerns?
Your help is much appreciated, Paul.  As always.
Offline Rosinante
Reply #11 on: December 26, 2021, 06:43:07 AM
Between terminals 31 and 33, there is 256 VDC.
On the DC Filament Supply board:
Right side Reg + and Reg -     6.28 VDC
Left side Reg + and Reg -        6.22 VDC
Offline Rosinante
Reply #12 on: December 26, 2021, 07:18:37 AM
Terminal 25 - 0 VDC
Terminal 30 - 0 VDC
Terminal 6 - 253.9 VDC
Terminal 16 - 253.8 VDC
All these voltages are with tubes removed.
Reply #13 on: December 26, 2021, 08:11:48 AM
Why don't you bring it by when the snow melts a little.
Offline Rosinante
Reply #14 on: December 26, 2021, 08:23:56 AM
Alright.
