Exactly What Is A PETP Capacitor?
Grainger49 · 20610
on: December 23, 2010, 09:45:23 AM
I have some KKs that are K73-16.  They are PETP, but what is PETP?  And how good is that as a dielectric?
Thanks in advance.
Offline xcortes
Reply #1 on: December 23, 2010, 10:36:11 AM
PTFE
Xavier Cortes
Reply #2 on: December 23, 2010, 10:43:19 AM
These don't look like the Russian Teflons, PTFE, they are green on the ends and I believe were sold as PETP.  Sounds like a lot of alphabet soup.
Reply #3 on: December 23, 2010, 11:45:41 AM
From Wikipedia:  "Polyethylene terephthalate (sometimes written poly(ethylene terephthalate)), commonly abbreviated PET, PETE, or the obsolete PETP or PET-P..."  Think Dacron sails and polyester Nehru jackets. Also called Mylar.
Reply #4 on: December 23, 2010, 01:24:13 PM
Thanks, I know PET as the plastic in soda bottles.  Mylar I also know but didn't know they were the same stuff.
Were Nehru jackets Polyester?  (remember them well, didn't have one)
Are they supposed to be good sounding caps?
Reply #5 on: December 25, 2010, 03:53:36 PM
Mylar is used in many caps, and even sometimes is also found in the paper of some otherwise labeled paper caps.  I believe the Jupiter HT series is actually a paper/mylar blend of some sort, but it is still described as paper.  I believe only the orginal "wax candle" type Jupiters are the only ones that had a pure paper dielectric.  Also, they now say so, but I suspect that the original Audio Note PIOs -- copper, silver and tin -- also had a paper with a certain percentage of mylar in it.  And of course there are dozens of metalized polyester types.  Auricaps, for example.
Have you given them a listen yet?
Reply #6 on: December 25, 2010, 05:39:16 PM
I think that Auricaps are metallized polypropylene rather than polyester.
Reply #7 on: December 26, 2010, 01:28:28 AM
Jim,
I have used them as power supply bypass only.  I will give them a listen in something soon.
Thanks for the information.  It is encouraging.
Offline ToolGuyFred
Reply #8 on: December 27, 2010, 03:27:08 AM
I find that the relative permitivity or dielectric constant is often a fair guide to a material's "goodness" for use in an audio capacitor:
Vacuum1 (by definition)
Air1.0006
PTFE2.1
Polypropylene2.2-2.36
Polystyrene2.4-2.7
PETP3
Polyimide3.4
Paper (unoiled)3.5
Transformer Oil4
Mica3-6
Glass5-10
(Information from Wikipedia, ElectricianEducation.com and Goodfellow.)
Hope this is useful.
John
Amateur Audiophile and Backstreet Boffin.
Original Foreplay with C4S + Sweet Whispers
ParaSEX amps with MQ nickel-cored outputs
Factory-built Lowther Acousta 115s with silver-coiled DX3s, wired in DNM solid-core
KEF active sub (help for the last couple of octaves).
Bottlehead DAC on batteries.
Reply #9 on: December 27, 2010, 05:17:10 AM
Dan is right, I mistated on he auricaps.
John, thanks for the table.  Don't see cotton, silk, or polycarbonate on there -- there are some new caps coming out with polycarbonate dielectric now, but I have no idea how they sound.
Reply #10 on: December 27, 2010, 06:12:54 AM
Fred,
Thanks, I have some air dielectric parallel plate capacitors.  I probably won't try them though. (Picture turned upside down to make more sense)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi244.photobucket.com%2Falbums%2Fgg7%2FGrainger49%2FIMG_0291.jpg%3Ft%3D1293469920&hash=bb88226d26db973ceb3435c078ce367acddd022a)
Good list!  Funny, it follows much of what I have experienced and heard elsewhere.  My true confusion was not knowing that my new KKs were made of old Nehru Jackets (Dacron/Polyester).
« Last Edit: December 27, 2010, 01:11:26 PM by Grainger49 »
Offline ToolGuyFred
Reply #11 on: December 27, 2010, 11:45:16 AM
Can't find any values for silk.
Polycarbonate2.9
Cotton1.3-1.4
The polycarbonate & foil caps I have heard were OK but only available in low values.
Cotton will only maintain this value if kept bone dry - some sort of oil or resin would keep the moisture out - but I suspect that would seriously impact the dielectric constant.
John
Reply #12 on: December 27, 2010, 03:35:35 PM
John,
Thanks, and I am also looking at this from a wire insulation perspective as well.
Lie Grainger, most of this agrees with what I've heard (though have not heard any polycarbonate caps myself yet)  That said, I'm not a huge fan of teflon on wire, but in caps, I do mostly like it.
Offline Dyna Saur
  • Yippie-Ki-Yay....
Reply #13 on: January 05, 2011, 03:24:10 PM
Then there are the caps which are not really that  which they appear to be:
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fwww.pastisch.se%2Ffaktiskt%2F20071207-214523.jpg&hash=6693de5e604505a91f32d68886333faf1a019854)
Saw this one  over at the www.diytube.com website
/ed B in NC
ed brown
Reply #14 on: January 05, 2011, 05:03:51 PM
Yow! That's scary.
Speaking of scary, thanks for the link - I didn't know of that site. Under SC35 there's a thread on standby switches in the center tap of the power transformer - exactly what I've been telling people for years based on theory, and nobody every buys it. But it's true nonetheless - switching high voltage DC will destroy switches. Nice to see that experience nears out the theory!
