Volume Control not working
hpleung · 4238
Reply #15 on: January 12, 2022, 01:02:34 PM
What is the resistance between the upper outer pair of lugs on the volume pot?
Offline hpleung
Reply #16 on: January 12, 2022, 01:59:35 PM
So between the upper outer pair of lugs of the volume pot, the resistance is 96.2kohm.
Reply #17 on: January 12, 2022, 02:09:04 PM
What is the resistance between the upper outer pot lug and the shell of the left RCA jack?
What is the resistance between the upper inner pot lug and the center pin of the left RCA jack?
Offline hpleung
Reply #18 on: January 12, 2022, 03:22:39 PM
I am assuming left RCA jack means the RCA Jack where the red wire is connected. This is using the orientation as per the manual.
96.4 kohm
91.6 kohm
Reply #19 on: January 12, 2022, 03:33:36 PM
red - right
white - left
Reply #20 on: January 12, 2022, 03:39:35 PM
You have some situations that are looking paradoxical.  I don't suppose you might have a loose black wire on your headphone jack?
Offline hpleung
Reply #21 on: January 12, 2022, 04:35:19 PM
Using left is white wire.
96.5 kohm still
Its also 96.5 kohm
I do not see any loose black wire.
I am going to do another pass at re-soldering all the connections.
Reply #22 on: January 12, 2022, 04:47:12 PM
96.5 kohm still
Its also 96.5 kohm
I noticed my red RCA center pin has 90.7 kohm but my white RCA center pin has OL resistance. I believe this is also supposed to be 90.7 kohm. Wanted to confirm this - note this has the speedball upgrade.
These conditions should be able to happen at the same time.  Can you recheck the resistance between terminal 12 and the center pin of the left RCA jack?
Offline hpleung
Reply #23 on: January 13, 2022, 08:22:52 AM
Hi,
So, I resolved the issue and the Crack is back to working and sounding excellent as it was. My apologies for taking so long on this and thanks for the support along the way.
Yesterday, I reinspected all connections and resoldered any connection that looked remotely suspicious. In particular, I removed all the solder from my potentiometer (from all lugs) and started from scratch. At this point, I think what contributed to the issues in this long thread is poor soldering of the potentiometer. It is a good learning because when I looked at the soldering prior to this, it looked fine to me but clearly there was still some issue.
Still got a question though - The crack sounds good.
However, when I measure the resistance from 12U to the Middle of Red RCA Plug is about 96.5kohm.
The same value for the White RCA Plug is about 92.5 kohm.
They are a bit different - is that ok or does that mean the potentiometer is slightly damaged from all this resoldering? Sonically, I cannot tell.
Thanks.
Reply #24 on: January 13, 2022, 08:35:30 AM
That difference is pretty typical, and not a big deal.
