Quick schematic question [resolved]
Neuronal · 15189
Offline Neuronal
    • Datta Lab Website
on: February 01, 2022, 01:50:17 PM
Hi - I'm upgrading the interstage cap in my 1.1 Paramounts, and the duelund caps I am trying advise to connect the outer foil to the lowest impedance path to ground. Just checking - that means to connect that lead to terminal 7, in other words connected to the 249K resistor to ground. Thanks for confirming - don't want to mess this up!
« Last Edit: February 01, 2022, 03:16:43 PM by Paul Birkeland »
Bob D
Rega P2, Cosecant DAC, Reduction, EFP III, Paramount V1.0 + soft start, Omega CAMs + DeepHemp 8s
Reply #1 on: February 01, 2022, 03:06:18 PM
I would connect the outer foil toward the plate of the driver tube rather than the 249K resistor, as the internal impedance of a 5670 is much, much lower than 249K.
Offline Neuronal
    • Datta Lab Website
Reply #2 on: February 01, 2022, 03:14:03 PM
thanks - I'm glad I checked!
Bob D
Reply #3 on: February 01, 2022, 03:16:34 PM
I mean the signal level there is enormous, so you're not going to notice either way I suspect.  On the other hand, if you put them in with the outer foil toward the output grid and you changed your mind later, then you'd have to do it twice!
