Bottlehead Kits
Crack
loud hum
loud hum
bucketofguts
6967
3
4
Paul Birkeland
Global Moderator
Hero Member
Re: loud hum
Reply #30 on:
March 08, 2022, 03:37:11 PM
What voltage do you see at terminal 22?
bucketofguts
Full Member
Re: loud hum
Reply #31 on:
March 08, 2022, 04:28:06 PM
97.6V
Power on
Valves in
Thank you. You are a gentleman and a scholar.
Paul Birkeland
Global Moderator
Hero Member
Re: loud hum
Reply #32 on:
March 08, 2022, 04:39:47 PM
Can you perform the AC voltage checks for the power transformer again?
I would also suggest reheating and adding some solder to all the solder joints with UF4007 diodes, especially if the transformer AC voltage checks are correct (which I suspect they are).
bucketofguts
Full Member
Re: loud hum
Reply #33 on:
March 08, 2022, 04:54:44 PM
Thank you. Will do.
is there a resistance value across those diodes that I should be looking for? Could one or both be faulty? (I see four)
Where are the ac terminals on the transformer? help.....
Last Edit: March 08, 2022, 05:10:01 PM by bucketofguts
Paul Birkeland
Global Moderator
Hero Member
Re: loud hum
Reply #34 on:
March 08, 2022, 05:29:24 PM
Page 29 in the manual provides the test for the power transformer.
When diodes like those fail, they tend to explode, so I don't believe that's worth looking at just yet.
bucketofguts
Full Member
Re: loud hum
Reply #35 on:
March 08, 2022, 05:38:36 PM
I measured 6.24 V AC as shown on page 29. (I have the exact same multi meter)
Paul Birkeland
Global Moderator
Hero Member
Re: loud hum
Reply #36 on:
March 08, 2022, 05:39:36 PM
How about for the high voltage winding?
bucketofguts
Full Member
Re: loud hum
Reply #37 on:
March 08, 2022, 05:45:55 PM
174.9
Paul Birkeland
Global Moderator
Hero Member
Re: loud hum
Reply #38 on:
March 08, 2022, 06:03:34 PM
What's the DC voltage between 20 and 21?
bucketofguts
Full Member
Re: loud hum
Reply #39 on:
March 08, 2022, 06:17:03 PM
Thank you ! That will have to wait. It is not my fault.
b~
bucketofguts
Full Member
Re: loud hum
Reply #40 on:
March 08, 2022, 06:33:01 PM
97.5 on both. thank you!
b~
Paul Birkeland
Global Moderator
Hero Member
Re: loud hum
Reply #41 on:
March 08, 2022, 07:07:55 PM
Terminal 20 is grounded. If terminal 20 has 97.5V on it, it's not grounded, and one of your black wires is loose (there are only two black wires between this terminal and terminal 12).
bucketofguts
Full Member
Re: loud hum
Reply #42 on:
March 09, 2022, 02:59:39 AM
I will replace both with new wire, test and get back. Thank you kind sir. Lots to do today, out the door "in the rain". Will post as soon as I can. Probably this evening EST.
b ~
Paul Birkeland
Global Moderator
Hero Member
Re: loud hum
Reply #43 on:
March 09, 2022, 04:31:47 AM
The wires are probably OK; it's more likely to be a solder joint issue.
bucketofguts
Full Member
Re: loud hum
Reply #44 on:
March 09, 2022, 08:42:49 AM
(there are only two black wires between this terminal and terminal 12). I know that sounds easy but what two black wires. I have sucked, chem-wik, and soldered and still no joy. I am sorry to have ask.
b~
3
4
Bottlehead Kits
Crack
loud hum
