Measuring low voltage at IEC [resolved]
smodtactical · 2035
Offline smodtactical
on: March 10, 2022, 12:29:09 PM
I got to the step where you measure AC Voltage but the voltage is not really changing when the amp is plugged in and the switch is turned on. It consistently measures 0.3 volts. I included pictures of my soldering below. Thanks.
« Last Edit: March 10, 2022, 05:24:01 PM by Paul Birkeland »
Reply #1 on: March 10, 2022, 12:29:57 PM
By the way the fuse is in the socket. Power cable use works on my amp and other devices connected to outlet work and are on.
Reply #2 on: March 10, 2022, 12:35:50 PM
Here is a picture of how my multimeter is set. In the pic its not connected to anything.
Reply #3 on: March 10, 2022, 01:52:09 PM
Is the fuse installed?
Reply #4 on: March 10, 2022, 03:15:36 PM
Yup. I measured resistance across the fuse too and its 0.4 ohm so i think its ok.
I attached  how I have the leads connected (via alligator clips).
Reply #5 on: March 10, 2022, 03:23:47 PM
You might try just using the probes without the clip leads.  Sometimes you get a clip lead that just doesn't work.  Also be sure the fuse is in the small clip, not the hollow square tube.
Offline kgoss
Reply #6 on: March 10, 2022, 03:24:42 PM
I believe there is a spare fuse holder section and the section that puts it in the circuit. You might have the fuse in the wrong place.  That is how the fuse holder used to be anyway.
Ken Goss
Reply #7 on: March 10, 2022, 03:38:38 PM
Oh my god I think I have it in the fuse holder compartment, ill try to put it in the other section.
Reply #8 on: March 10, 2022, 05:16:46 PM
It worked! Thank you guys!!!
