BeePre2 Build
Audionut · 9229
Offline Audionut
on: May 01, 2022, 01:10:09 PM
So I’m working on my first bottlehead kit build and have been having a great time (so long as voltage or resistance checks match). I hit a bit of a wall on my resistance checks for pages 52/53. A4 was good (447), A1 was off (591).
B4 and B1 were both off at 247 (should be around 445). I checked back at the DC bird and the measure the same there (beginning of green wire). Can’t load iPhone pic (jpeg).Thanks in advance for your help.
Reply #1 on: May 01, 2022, 01:24:26 PM
Can you hop on a computer and post some build photos?
Offline Audionut
Reply #2 on: May 01, 2022, 01:31:32 PM
I was able to convert the format.
Reply #3 on: May 01, 2022, 01:37:32 PM
If I had to guess, you've swapped a pair of resistors. What DC resistances do you get at 25 and 30?  (They will take a bit of time to stabilize as the cap charges up from your meter).
It seems likely that you have three 130 ohm resistors on the B side and two 330s and one 130 on the A side.
Offline Audionut
Reply #4 on: May 01, 2022, 01:40:20 PM
327 on 25, 129 on 30.
Reply #5 on: May 01, 2022, 02:00:55 PM
Those should both be 330.  You have a 130 ohm resistor installed where it shouldn't be on the B side.
Offline Audionut
Reply #6 on: May 01, 2022, 03:35:01 PM
A big thank you! I’ll go back and check the resistors. Here are a couple pics I was going to post. Thought I had the right ones in place.
Offline Audionut
Reply #7 on: May 17, 2022, 05:04:49 PM
Success! That fixed the issue and after some additional soldering I have sound! Substantially better drive and dynamics than my prior pre (Schiit Freya) in my early listening. However, the balance does not seem right. The left is much stronger and I need to turn the knob to nearly 3pm to more or less be even. I swapped rca cables, signal source, even HF drivers and no dice so thinking it’s the balance pot? Thanks in advance.
Reply #8 on: May 17, 2022, 05:33:51 PM
What are your DC voltages?  Are you certain you have the pots in the correct holes?
Offline Audionut
Reply #9 on: May 17, 2022, 06:06:13 PM
They weren’t spot on but close. I’ll turn it off and check shortly.
Offline Audionut
Reply #10 on: May 17, 2022, 06:28:28 PM
First one is 9.78, second is 9.85, the third is 99.5, fourth is 99.7.
I installed giant jantzen supreme z caps, one lead is close to the edge of its own casing, I doubt that would be the issue?
« Last Edit: May 17, 2022, 07:30:01 PM by Audionut »
Reply #11 on: May 17, 2022, 07:51:45 PM
I would check to be sure the 10K log pot made it into the volume control hole and the 100K linear made it into the balance spot.  You'll get really wonky channel balance if they are swapped.
Offline Audionut
Reply #12 on: May 18, 2022, 03:29:21 PM
And you are right again! I must have mixed them up when looking at the orientation (they are clearly marked on the front but not backside). Thanks again! I’ll post some build pics so it’s not just a trouble shoot thread.
Offline Audionut
Reply #13 on: July 09, 2022, 08:29:19 AM
A big thanks again for all the help (hand holding). I’ve been really enjoying this preamp and almost forgot about the upgrade. I’ll be taking it out of commission to install the bee quiet. I’ll also be building a custom base in an exotic wood (TBD).
Reply #14 on: July 09, 2022, 05:24:56 PM
Nice, I like the top plate finish...John
