Left channel getting signal before the right ?
kdogsy · 1987
Offline kdogsy
on: June 29, 2022, 08:24:41 AM
Hi Bottleheads
This is my first post here so hope I'm obeying the rules!!!
I put theocracy together on the weekend. Everything went smoothly and all tested within acceptable limits.
Loving the sound and currently breaking in 650's and a couple of tubes.
My question: when I turn the volume to extremely low level (just before off) I notice that I pretty much only get signal in the left channel.
When I turn up the volume the right channel kicks in and as far as I can tell it seems to be at the same volume as the left so i don't really have an issue.
I did want to ask ya'll if this is normal or if you think I need to look into it?
Online Paul Birkeland
Reply #1 on: June 29, 2022, 09:10:36 AM
That can be normal with carbon potentiometers.  Crack FAQ #3 has a solution for this issue if this happens to be a reasonable listening level in your system.
https://forum.bottlehead.com/index.php?topic=4295.0
Offline kdogsy
Reply #2 on: June 29, 2022, 09:54:22 AM
Thanks Paul this is great!!!
It doesn't really bother me so Its good to have you reassure me everything is working a it should.
Maybe I will look into that solution if i feel the need to tinker.
Reply #3 on: June 29, 2022, 10:12:18 AM
Quote
Seems to be a common activity these days.
Offline Deluk
Reply #4 on: June 30, 2022, 03:15:21 AM
LOL  :D
Offline kdogsy
Reply #5 on: June 30, 2022, 07:58:06 AM
hahahhaha oh dear...
lucky I double checked my soldering more thoroughly than my spelling
